What version of Windows are you using If Windows 10 which Build. Dxdiag can be run by pressing Windows key + R then type dxdiag in run box. Then save all. The file it makes link me in a DM. Sent from my SNE-LX1 using Tapatalk
Edition Windows 10 Home Single Language Version 20H2 Installed on 7/1/2020 OS build 19042.685 Experience Windows Feature Experience Pack 120.2212.551.0 I will send you Dxdiag. Thank you!
Possibly useful drivers for a new release over the msi driver thread ? OgUrecheK posted some new realtek and nahimic files.
Found it, we are already on the same driver as posted only difference is the APO driver is V4 and not V3. Sent from my SNE-LX1 using Tapatalk
Ah right I got you will make a modded pack version soon enough lol. My brain is not working right from all this Lock Down isolation which started in March 2020. Downloaded the Driver, waiting on my server to finish the Router Firmware compiling and i will then start moding the driver I am also going to be refactoring the Device ID's again so i can get ready to test APO v4 on Older then 10th Gen systems.
Made By:hacktrix2006 and djlenior Status: Final Release Repack: No Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems! Due to this being a Modified Driver, support will not be given via Nahimic or MSI if your having issues please post in the thread! Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results, Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included. Updated Drivers and Nahimic 3 UWP Application Installer: Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe (ONLINE!) Package includes: Realtek UAD 6.0.1.9079.1 Nahimic 1.5.4.0 UWP Nahimic SWC 3.1.0.0 Nahimic Extension 1.1.41.0 Nahimic Mirroring Driver 1.0.3.0 / 8.51.48.758 Realtek Audio Console UWP 1.20.238.0 Installer: SHA-1: A279C3FB133E9E3D0A339D48CF288A62D910585E Size: 79205975 bytes (75 MiB) Virus Total: Result For Windows 10 Build: 1903/1909/20H1/20H2 Change Log: Code: Updated Realtek Audio Drivers from 6.0.1.9071.1 to 6.0.1.9079.1 Updated Nahimic 3 UWP from 1.5.2.0 to 1.5.4.0 Organised / Refactored Device ID's which will now have either ; HDA Converted to UAD or ; Modded In Tags. (In preperation for Beta Testing on Nahimic APO v4 modding), If your device isn't working please report it with Device ID's. Supported Systems with this driver pack: Alpha Series Spoiler Alpha 15 Bravo Series Spoiler Bravo 15 Bravo 17 GE Series Spoiler GE60 (Apache) (Pro) GE62 Apache (Pro) GE63 Raider (RGB) GE65 Raider GE66 Raider GE70 (Apache) (Pro) GE72 Apache (Pro) GE73 Raider (RGB) GE75 Raider GF Series Spoiler GF62 GF63 (Thin) GF65 Thin GF72 GF75 Thin GL Series Spoiler GL62 GL63 GL65 (Leopard) GL72 GL73 GL75 (Leopard) GP Series Spoiler GP60 (Leopard) GP62 Leopard (Pro) GP63 Leopard GP65 Leopard GP70 (Leopard) (Pro) GP72 Leopard (Pro) GP73 Leopard GP75 Leopard GS Series Spoiler GS40 Phantom GS43 Phantom Pro GS60 Ghost (Pro) GS63 Stealth (Pro) GS65 Stealth (Thin) GS66 Stealth GS70 Stealth (Pro) GS72 Stealth (Pro) GS73 Stealth (Pro) GS75 Stealth GT Series Spoiler GT60 (Dominator) GT62 Dominator (Pro) GT63 Titan GT72 Dominator (G) (Pro) (VR) GT73 Titan (Pro) GT75 Titan GT76 Titan (DT) GT83 Titan (SLI) GV Series Spoiler GV62 GV63 GV72 ***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.*** Install instructions: - Disconnect from the internet. (Not Required, so very Optional) - Reboot System and Enter BIOS/UEFI. - Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer! - Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!). - Now run the Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe Installer - Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3. - Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again! - Now head back into your BIOS/UEFI and Re-enable SecureBoot!! - Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet) ***[IMPORTANT]**** Known possible bugs and fixes: Issue: Two Nahimic Mirroring device show up in Device Manager: Solution: run Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install. Issue: Nahimic 3 updated via Windows 10 Store and no longer works. Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates, then run Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic. Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.5.2.0 UWP effects are not working or its reporting the device is not upto date. Solution: Simply run Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe and select Full Install. Issue: Jack Detection not working. Solution: Simply go to Realtek Audio Console Disable and Re-enable it. Issue: Microphone not working after using Nahimic Optimizer. Solution: Click Reset inside Nahimic Settings section will fix this. Issue: Microsoft Overwritten the installed modded driver. Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot the system. Then run Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe and select Full Install. Issue: Nahimic 3 reports its device is not compatible basically not working. Solution: Run Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe and select Full Install. Issue: Sound has become muffled/suppressed/distorted. Solution: Run Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe and select Full Install. Issue: I don't want the Nahimic 3 Bloatware! Solution: Run Realtek_UAD_6.0.1.9079.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic ***[IMPORTANT]**** I would like to thank the following people for whom have helped. I like to personally thank the following users. Project Programmers: Spoiler hacktrix2006 djlenoir Installer Testers: Spoiler DimitriosMSI TikiThorsen Driver Suppiler Spoiler MSI Original Thanks: Spoiler epguy3 J95 JeanLegi LeftEyeNine Falkentyne mnomaanw felix3650 asm1 Bazgrim ixende MrBeer arke yyci Beemo senso Eflatun HitZ2976 Ivan994 Alanfox2000 OneOnline OgUrecheK comradeskeleton (Reddit) eiraku @asm1 Please update the OP with new links when you have time.
@hacktrix2006 After install latest version, mic's echo and lateral sound cancellation couldn't be turned on. Is there any fix? thanks in advance
