Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    Dude let me wake up, dam!
    Take it normal MSI link.
    Edit: right with coffee inside me I have made the new pack but now testing.
    Sent from my SNE-LX1 using Tapatalk
    djlenoir and virgolicidaniel like this.
  2. hacktrix2006
    Made By:hacktrix2006 and djlenior
    Status: Final Release
    Repack: No
    Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookReview or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems!
    Due to this being a Modified Driver, support will not be given via Nahimic if your having issues please post in the thread!
    Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results,
    Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included.
    Updated Drivers
    Installer: Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
    Package includes:
    Realtek UAD 6.0.1.9071.1
    Nahimic 1.5.2.0 UWP
    Nahimic SWC 3.1.0.0
    Nahimic Extension 1.1.41.0
    Nahimic Mirroring Driver 1.0.3.0 / 8.51.48.758
    Realtek Audio Console UWP 1.20.238.0
    Installer:
    SHA-1: 9E923A9B747DEAC5128D43D81F8ED12D6D126EC2
    Size: 79277345 bytes (75 MiB))
    Virus Total: Result
    For Windows 10 Build: 1903/1909/20H1/20H2
    Change Log:
    Code:
    Updated Installer Logic for Microsoft Windows 10 Driver Updates via WSUS.
    Updated Driver from 6.0.1.9057.1 to 6.0.1.9071.1
    Supported Systems with this driver pack:
    Alpha Series
    Alpha 15
    Bravo Series
    Bravo 15
    Bravo 17
    GE Series
    GE60 (Apache) (Pro)
    GE62 Apache (Pro)
    GE63 Raider (RGB)
    GE65 Raider
    GE66 Raider
    GE70 (Apache) (Pro)
    GE72 Apache (Pro)
    GE73 Raider (RGB)
    GE75 Raider
    GF Series
    GF62
    GF63 (Thin)
    GF65 Thin
    GF72
    GF75 Thin
    GL Series
    GL62
    GL63
    GL65 (Leopard)
    GL72
    GL73
    GL75 (Leopard)
    GP Series
    GP60 (Leopard)
    GP62 Leopard (Pro)
    GP63 Leopard
    GP65 Leopard
    GP70 (Leopard) (Pro)
    GP72 Leopard (Pro)
    GP73 Leopard
    GP75 Leopard
    GS Series
    GS40 Phantom
    GS43 Phantom Pro
    GS60 Ghost (Pro)
    GS63 Stealth (Pro)
    GS65 Stealth (Thin)
    GS66 Stealth
    GS70 Stealth (Pro)
    GS72 Stealth (Pro)
    GS73 Stealth (Pro)
    GS75 Stealth
    GT Series
    GT60 (Dominator)
    GT62 Dominator (Pro)
    GT63 Titan
    GT72 Dominator (G) (Pro) (VR)
    GT73 Titan (Pro)
    GT75 Titan
    GT76 Titan (DT)
    GT83 Titan (SLI)
    GV Series
    GV62
    GV63
    GV72
    ***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.***
    Install instructions:
    - Disconnect from the internet. (Not Required, so very Optional)
    - Reboot System and Enter BIOS/UEFI.
    - Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer!
    - Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!).
    - Now run the Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod.exe Installer
    - Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3.
    - Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again!
    - Now head back into your BIOS/UEFI and Re-enable SecureBoot!!
    - Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet)
    ***[IMPORTANT]****
    Known possible bugs and fixes:
    Issue: Two Nahimic Mirroring device show up in Device Manager:
    Solution: run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install.
    Issue: Nahimic 3 updated via Windows 10 Store and no longer works.
    Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates,
    then run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
    Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.5.2.0 UWP effects are not working or its reporting the device is not upto date.
    Solution: Simply run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run
    Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Jack Detection not working.
    Solution: Simply go to Realtek Audio Console Disable and Re-enable it.
    Issue: Microphone not working after using Nahimic Optimizer.
    Solution: Click Reset inside Nahimic Settings section will fix this.
    Issue: Microsoft Overwritten the installed modded driver.
    Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot
    the system. Then run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Nahimic 3 reports its device is not compatible basically not working.
    Solution: Run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
    Issue: Sound has become muffled/suppressed/distorted.
    Issue: I don't want the Nahimic 3 Bloatware!
    Solution: Run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
    ***[IMPORTANT]****
    I would like to thank the following people for whom have helped. I like to personally thank the following users.
    Project Programmers:
    hacktrix2006
    djlenoir
    Installer Testers:
    DimitriosMSI
    TikiThorsen
    Driver Suppiler
    MSI
    Original Thanks:
    epguy3
    J95
    JeanLegi
    LeftEyeNine
    Falkentyne
    mnomaanw
    felix3650
    asm1
    Bazgrim
    ixende
    MrBeer
    arke yyci
    Beemo
    senso
    Eflatun
    HitZ2976
    Ivan994
    Alanfox2000
    OneOnline
    OgUrecheK
    comradeskeleton (Reddit)
    eiraku
    @asm1 Please update the OP with new links when you have time.
  3. hacktrix2006
    Please users, if you have issues within the supporting parameters let me know, Parameters are it has to be an MSI System!
  4. asm1
    asm1 Notebook Evangelist
    Teapot... er I mean Updated :D
    hacktrix2006 likes this.
  5. hacktrix2006
    Repack: Yes
    Updated Drivers
    Installer: Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod-repack.exe (ONLINE!)
    Package includes:
    Nahimic 1.5.2.0 UWP
    Nahimic SWC 3.1.0.0
    Installer:
    SHA-1: 537EC8E5DB18A0D045375007F128F64C22CE0339
    Size: 79276580 bytes (75 MiB)
    Virus Total: Result
    Change Log:
    Code:
    Fixed a typo that was causing audio issues. (Should of drank more coffee!)
    Alpha Series
    Alpha 15
    Bravo Series
    Bravo 15
    Bravo 17
    GE Series
    GE60 (Apache) (Pro)
    GE62 Apache (Pro)
    GE63 Raider (RGB)
    GE65 Raider
    GE66 Raider
    GE70 (Apache) (Pro)
    GE72 Apache (Pro)
    GE73 Raider (RGB)
    GE75 Raider
    GF Series
    GF62
    GF63 (Thin)
    GF65 Thin
    GF72
    GF75 Thin
    GL Series
    GL62
    GL63
    GL65 (Leopard)
    GL72
    GL73
    GL75 (Leopard)
    GP Series
    GP60 (Leopard)
    GP62 Leopard (Pro)
    GP63 Leopard
    GP65 Leopard
    GP72 Leopard (Pro)
    GP73 Leopard
    GP75 Leopard
    GS Series
    GS40 Phantom
    GS43 Phantom Pro
    GS60 Ghost (Pro)
    GS63 Stealth (Pro)
    GS65 Stealth (Thin)
    GS66 Stealth
    GS70 Stealth (Pro)
    GS72 Stealth (Pro)
    GS73 Stealth (Pro)
    GS75 Stealth
    GT Series
    GT60 (Dominator)
    GT63 Titan
    GT73 Titan (Pro)
    GT75 Titan
    GT76 Titan (DT)
    GT83 Titan (SLI)
    GV Series
    GV62
    GV63
    GV72
    - Now run the Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod-repack.exe Installer
    ***[IMPORTANT]****
    Solution: run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod-repack.exe and select Uninstall first before using Full Install.
    then run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod-repack.exe and select Downgrade Nahimic.
    Solution: Simply run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod-repack.exe select Uninstall and then after its completed the Uninstall re-run
    Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod-repack.exe and select Full Install.
    the system. Then run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod-repack.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod-repack.exe and select Full Install.
    Solution: Run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod-repack.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod-repack.exe and select Full Install.
    Solution: Run Realtek_UAD_6.0.1.9071.1_MSI_Nahimic_UWP_mod-repack.exe and select Install Without Nahimic
    ***[IMPORTANT]****
    hacktrix2006
    djlenoir
    Installer Testers:
    DimitriosMSI
    TikiThorsen
    Driver Suppiler
    MSI
    Original Thanks:
    epguy3
    J95
    JeanLegi
    LeftEyeNine
    Falkentyne
    mnomaanw
    felix3650
    asm1
    Bazgrim
    ixende
    MrBeer
    arke yyci
    Beemo
    senso
    Eflatun
    HitZ2976
    Ivan994
    Alanfox2000
    OneOnline
    OgUrecheK
    eiraku
    @asm1 Please update the OP with new links when you have time, sorry about this a typo killed the original one oooopsies.
    zboq, TikiThorsen and virgolicidaniel like this.
  6. asm1
    Updated the update :p:p
    virgolicidaniel and hacktrix2006 like this.
  7. asm1
    If anyone wants a laugh, I updated the page for the update, downloaded the update and then ran the installer for the one that didn't work, and promptly sat for 10 minutes wondering why nothing was happening :biglaugh::biglaugh::biglaugh:
  8. hacktrix2006
    Really! OMG Sorry dude
    Also Nahimic purged all the threads on Nahimic 3 on unsupported hardware.
    asm1 likes this.
  9. asm1
    Nah it's ok, tired, shouldn't mess when going to bed. I think I've had this chat with you before ;)
  10. hacktrix2006
    Just a heads up to everyone, I managed to break my VM Host Server in a funky way, only way to fix it is to Backup the important files and then remake the VM Host Server from scratch. This will mean any new mod packs is now on hold till i have fixed the issue.
