Nahimic 3 on "unsupported systems"
Discussion in 'MSI' started by asm1, Sep 7, 2018.
  1. hacktrix2006
    Right how many audio port is on your laptop, is it 1 2 or 4?
    If you have 4 Audio jack's it should be starting from the front of the laptop in order
    1) Digital Audio
    2) Microphone
    3) Line In
    4) Line Out
    Just remember I am working blind here.
    So are you able to click on your Speaker Icon on Windows 10 and screen shot the options shown in there.
    Should be showing more then one option, if you are Digital Output give that a shot as headphone mode doesn't work for me but Digital Output also known as S/PDIF does.
    Also I don't know what Audio Codec ID your using.
    A dxdiag log would help.
    Sent from my SNE-LX1 using Tapatalk
  2. DYKTATORR
    DYKTATORR Newbie
    I don't know what's going on ;)
    Yesterday, I did the FullInstall and FullUninstall and InstallWithoutNahimic, DowngradeNahimic3, several times - (sound didn't work). I turned off the computer
    Today, I turn on my computer, and there have been an information Nahimic 3 (please restart computer) - ok.
    Yesterday, this information didn't appear.
    The sound works. I don't know :D
    I'll see what happens in the next days
    thanks ;)
  3. virgolicidaniel
    virgolicidaniel Notebook Enthusiast
    nahimic updated to 1.5.1
    djlenoir and hacktrix2006 like this.
  4. hacktrix2006
    Will test for compatibility later. Thanks for heads up.
    Edit: Good news if you have been stuck on Nahimic 3 UWP 1.4.2 you can now upgrade to Nahimic 3 UWP 1.5.1 it works on Systems that are under 8th gen.
    I have now downloaded the new UWP and its dependencies ready for the next new Audio Driver pack update, which means Nahimic 3 UWP 1.5.1.0 will now be the default version.
  5. virgolicidaniel
    That's some good news ! Glad it works fine for all systems now. Waiting for the next release.
  6. djlenoir
    djlenoir Notebook Guru
    This is indeed good news! Glad that the community is no longer fragmented, and even more glad that I no longer have to take extreme measures to prevent my UWP apps from updating.
    hacktrix2006 likes this.
  7. epguy3
    epguy3 Notebook Evangelist
    well that's only good news for MSI systems only, hacktrix2006. :)
    the bad news is that Nahimic 3 UWP v1.5.1 may only work exclusively with most MSI systems and not with non-MSI brand systems (boooooooo, :( ) as I get the "Nahimic cannot be used - not compatible" error message when that version is installed on certain non-MSI machines like my old HP computer & using someone else's modded Realtek UAD Nahimic driver from github :( :(
  8. virgolicidaniel
    well isn't this repack meant for msi systems anyway ? o_Oo_O
  9. epguy3
    ok, at least one person from this thread in MSI forums did have a problem after the 1.5.1.0 Nahimic3 app update but managed to solve it by using the Nahimic APO Restore tool package (from the recent Realtek audio drivers) to get things working again
    edit - at least one person in ASRock forums had trouble with the 1.5.1 version of the Nahimic3 app not working on a certain ASRock board that was supposed to support Nahimic3 but another person there using an older Realtek audio driver with a slightly different ASRock mobo has the Nahimic3 v1.5.1 app working
  10. OgUrecheK
    OgUrecheK Notebook Geek
    The driver is only for MSI devices, the application must be universal.
Similar Threads - Nahimic unsupported systems
  1. Crustieraxe01
    502
