myUndervolt v1.0 - Adjust the voltage offset value & automatically under-volt your CPU at startup
Discussion in 'Alienware' started by marticztn, Dec 31, 2017.
  1. marticztn
    marticztn Newbie
    Under-volting your CPU will drop its temperature massively while gaming like never before, but please do it PROPERLY!!!
    For i7-7820HK + GTX 1080, 150 is the sweet spot for me, it might not work for you, so I would recommend you to test it out via CPU stress test, thanks to @MogRules for pointing out. A value of 150 is equal to the actual offset value of -0.150 V. The temperature dropped 25 degrees Celsius for me during the CPU stress test(approx).
    XTU's auto-applying feature is really unstable and it just doesn't work for me most of the time, so I thought it would be great to just write a little program based on the XTU's command line tool.
    I'll continue to improve the program in the future with new features and fixes. But for now, I just hope it helps
    If you found any bugs or errors, or if you have any suggestions about the program, please let me know in the comment below, I appreciate it!
    I just found a bug (prob related to process handling) which could cause the application to crash.
    UPDATE: Fixed, new link:
    https://drive.google.com/open?id=1DrFnzspmSJLNycC1kzqARyFaFU3JrXLx
    Vasudev and W00d_m3 like this.
  2. MogRules
    MogRules Notebook Deity
    Not everyone will have success at 0.150 , some will not be able to get that far as their chips won't handle it. Mine will lock up and restart if I try to drop it to those levels. Every laptop will be slightly different and they will have to find the sweet spot for their chips.
    Vasudev likes this.
  3. marticztn
    marticztn Newbie
    Yeah, -0.150 V should work for 7820HK, if it doesn't work on your device then I guess the reason why is because of the slight difference between silicons, that make sense
    I'll probably add a CPU stress test into the program, that should be a handy feature when it comes to testing between different state of CPUs from different PCs
    Vasudev likes this.
  4. Darker01
    Darker01 Notebook Geek
    Vasudev likes this.
  5. marticztn
    marticztn Newbie
    Yes, I saw that post as well, I was actually inspired by that post
    Of course, it's always nice to have a more advanced app there like ThrottleStop, I wouldn't compare my program with ThrottleStop though because myUndervolt is a very simple, small program and it's completely based on command line. The steps which you need to do are actually not that much (ik I wrote a bunch of texts there) and it's very easy to understand imo cuz there's just 1 feature available for right now.
    Vasudev likes this.
  6. Darker01
    Fair point. Still a pretty neat solution overall.
  7. marticztn
    marticztn Newbie
    Thank you so much!
  8. marticztn
    marticztn Newbie
    Thanks ;)
  9. W00d_m3
    W00d_m3 Notebook Enthusiast
    Can you reupload somewhere else like mega.nz for example?
  10. qajteq
    qajteq Notebook Enthusiast
    Hi, OP reupload please?
Similar Threads - myUndervolt Adjust voltage
  1. baba190
    297
