my XPS M1730 touchpad & Keyboard not working (HELP)
Discussion in 'Dell XPS and Studio XPS' started by bestmobileworld, Sep 26, 2010.
  1. bestmobileworld
    bestmobileworld Newbie
    hello!
    i am Noman From Pakistan
    i worked in GSM filed recently i got a Dell XPS M1730 from a friend, its a brand new laptop, its touch-pad, keyboard and charging not working i tried many time to solve it but fail, some time charging works some time keyboard works but only for some time then goes dead again.
    i open it and saw its very cleaned nobody touch it in inside not water damage and also no other damages
    i think if touch pad works properly then also keyboard will be OK and charging also will be fine, because when i remove touch-pad from PC AC power also off only battery power works when i attach again touch-pad AC power works again
    also i get error of AC adopter when i start PC that please connect AC230 power adopter and i already connect it with AC230 original power adopter :(
    any body can help me what is the problem i check all drivers working fine also i checked with windows XP, Vista and 7. when i saw device manager and i show hidden devices i saw dell touch-pad with yellow icon i checked it it show device not connected.
    please help me in this mater i will be very great full to you brothers
    thanks in advance
    BR:
    Noman
  2. bestmobileworld
    i run Dell™ Diagnostics and i got this error
    Error Code 3500:0119.
    Msg: Could not disable mouse. The keyboard controller did not acknowledge a mouse disable command.
  3. niffcreature
    niffcreature computer lesbian
    sounds bad.
    Is it under warranty?
    The control for touchpads and keyboards especially is not in the part, meaning if you replaced the keyboard and touchpad you may still have problems. So its likely the motherboard.
    Try running the diagnostic at different times like when you said you got it to work correctly.
    You could also try disconnecting the keyboard. Pry of the hinge cover (the part that has "XPS" in red letters), unscrew the 4 screws holding it down, and slide it up about 1/2" right after pressing the power button.
  4. bestmobileworld
    thanks for reply bro
    i tried many time your method touch pad naver works for me but key board some time works
    in test its 1 key not works the key is up side of tab key and before 1 key
  5. bestmobileworld
    hello friends
    i was waiting for reply but i thing no one see this messege
    please check it
    1 thing more when ever charging starts my keyboard start working
    now my charging light blinking 3 time in orange color and 1 time in blue color
    please try to solve my problem
    Br.
    Noman
  6. bestmobileworld
    i was waiting for so many days but no reply :cry: :cry: :cry: :cry: :cry: :cry:
  7. bestmobileworld
    i change cord that out from charger to pc and my charging problem solved but touchpad and keyboard same. not work any key aspect power.
    only power key works
  8. Kingpinzero
    Kingpinzero ROUND ONE,FIGHT! You Win!
    Power keys are located on the top bezel which is on an independent rail from the keyboard, althought they share the same connectors.
    I think that your problem is that the motherboard is going to die soon. The keyboard and touchpad controller hooks up with the palmrest area by a thin cable, located on the bottom left corner of the motherboard.
    Theres the controller too. I suspect that the controller is almost dead, remember that some motherboards where faulty, some others get faulty in the time, so maybe its your turn, which is sad.
    I advice to send it back to dell if you have any warranty left. If not, you can buy a new motherboard off ebay, they are cheap as well, so maybe with a little effort you can fix it by yourself.
    Anyway what happens if you plug in an usb mouse or keyboard, does it work ok? It should since they use the usb controller instead of the builtin keyboard controller.
    Good luck mate, im sorry to hear you're having problems with it.
