my notebooks HOT!!
Discussion in 'Linux Compatibility and Software' started by arjunned, Jul 14, 2008.
  1. arjunned
    arjunned Notebook Deity
    ok.. i've noticed over the past week that my notebook runs really hot..
    the cpu temp's are at abt 68 with lite usage like web surfing, and 65 while idling. the palm rest's are pretty warm but the bottom of the notebook's like an oven!!! the gpu temps fluctuate between 70 and 72 while idling and lite usage.
    these are temps are a bit too high as, while running vista, i never get temp's this high when idling, or even even surfing..:confused:
    is something wrong?? i'm pretty sure the fans are doing their job. are these temp's normal or should i be worried?:(
  2. theZoid
    theZoid Notebook Savant
    the GPU is ok...but the CPU temps seem high. I run about 55C on the Desktop CPU in this laptop......might wanna google that. I assume you've check your services to see what is running. Any indexing going on?
    EDIT: I just noticed we have the same Video Card. CPU is high though, this one is a Desktop CPU and it doesn't get that hot. I get from 68 to 72 on my GPU....using Mandriva KDE
  3. redrubberpenguin
    redrubberpenguin Notebook Consultant
    That's rather high. My CPU idles at about 40-45 C and hits 60 at load maximum (in rare cases, too). AND my notebook has a smaller form factor than yours. Did you just get this notebook? You might want to ask for a replacement if you did.
  4. arjunned
    no, no idexing going on. but is there a way to check whether indexing is on? i've had this notebook for abt 6 months now. dont get these high cpu temp's in vista. :(
    anythin else i can chk?
    EDIT: ok i think it has something to do with power management. can anyone help me with cpu frequency scaling? i think the cpu's running high even when its idling.
  5. theZoid
    I think it's a setting somewhere....you have CPU set to DYNAMIC right in power management?
  6. arjunned
    is that in the bios?
  7. theZoid
    No, go into a terminal and type
    gksu gnome-power-manager
    then look at the settings and make sure dynamic is selected. Also, look in services and make sure the cpu-freq module is loading I think....not in gnome now
  8. arjunned
    ok i typed in the code but nothing's happening. also wen i add the cpu frquency scaling monitor applet to the panel it says that frequency scaling is not supported?!?!!?!
  9. theZoid
    yeah, it's something with CPU scaling/power management....shouldn't be difficult to correct....someone using gnome needs to step in here........knock knock? :D I would say go to synaptic package manager and search the following: gnome-power-manager, and cpu-freq. See if they are installed, if so, I'd mark them to reinstall and reboot then go into gnome power manager....I just can't look at what you're looking at now. But that won't hurt anything for sure.
  10. theZoid
    I just installed Ksensors, then rebooted....at first it showed my CPU at 67 degrees! but after a while it dropped down to 55C which is normal for this CPU. Have you given it time to adjust?
