My notebook Cable Charger/Transformer is making a buzzing noise
Discussion in 'Hardware Components and Aftermarket Upgrades' started by TakedaYabu, Feb 13, 2019.
  1. TakedaYabu
    TakedaYabu Notebook Guru
    Hello everyone,
    I have an Acer Aspire 5742ZG (p614g32mnkk) and when I turn it off, it's possible to hear that there's a buzzing sound coming from my laptop Power Cable, specifically from the transformer...
    What does it mean? The cable and everything is working 100% fine though.
    https://www.techwalla.com/articles/what-does-it-mean-if-your-laptop-charger-buzzes
    I read this article and I'm positive it is this... What can I do?
  2. TakedaYabu
    Someone? Please...
  3. tilleroftheearth
    If you want to keep using the notebook without damaging it; a new adaptor is highly recommended.
    For a circa 2011 platform though; a new or newer-ish system is probably a wiser move.
    WhatsThePoint and TakedaYabu like this.
  4. TakedaYabu
    Hey there again.
    I bought a brand new power cable w/ transformer 100% compatible with OUTPUT specs, but the INPUT specs are slighty diferent but that's ok I guess.
    It's working 100%!!! No low volume beeping anymore =)
    Admin please mark this post as solved but don't delete it, cuz it might be useful for someone else in the future :)
    tilleroftheearth likes this.
  5. Casowen
    Casowen Notebook Evangelist
    What is your power source? I only get that issue when using a square sinc AC power source from a 12v to 110v power converters, while pure sine wont make that noise your describing.
  6. ALLurGroceries
    ALLurGroceries   Super Moderator
    This generally isn't a problem unless the sound really annoys you or it is super loud. The article you linked is completely incorrect. Most transformers make some sort of audible noise during normal operation.
  7. t456
    Indeed. A more reliable, more educated source:
    Why is there audible noise in an inductor?
    My 120W adapter made a similar noise. So opened it up, found the culprit inductor and swapped it for a compatible model. Completely silent now, but it'd have been fine to leave it as is, except for the annoyance factor, of course:
    Soft High Pitch Whine Heard From Power Brick: Cause of Concern?
    It's just a matter of resonance (an inductor carries heavy amps) and how good it was affixed to the pcb. That's why you'll find dollops of putty inside the adapter; they're there to counter resonance/vibration, but not always effectively so. And even then it's a matter of perspective, depending on the consumer's annoyance level threshold.
