My Late 2019 Razer Blade 15 Base Clocks Low by default? (2070 MQ)
Discussion in 'Razer' started by awsims33, Nov 9, 2019.
  1. awsims33
    awsims33 Newbie
    Hey guys just got my late 2019 blade with a 2070 in it
    I repasted and was testing temps when i realized my firestrike scores were low (15,800 ish) which is a good 3-400 from what i see other blade owners getting (stock clocks) I started digging at it looks like my base clock by default is 885 MHz when all of the review sites for this computer show the base clocks at 1080 MHz...
    Is this common? What base clocks are you guys seeing on your 2070s?
  2. bjrebo
    bjrebo Notebook Consultant
    My default on mine is 1080. Do you have synapse on the wrong profile? That is probably your cause. I get around 21k in firestrike with an OC and LM.
  3. nyichiban
    nyichiban Notebook Guru
    You have a 90W 2070 and that normally sits at the 885mhz. Once you flash to the 100W it will be at the 1080 like the reviews.
