My head is about to explode as I can't make my mind up for laptop replacement
Discussion in 'Lenovo' started by t61jaws, May 13, 2019.
  1. t61jaws
    t61jaws Notebook Consultant
    Hi
    Uk based.
    Im looking to replace my T420 i5 for a another Lenovo machine that can do 32gb Ram.
    I use my laptop for Music Production (DAW) Mostly sample based (Kontakt).
    To make things easier, I'll some useful info that might help you help me.
    I just bought a 43inch 4K which at the moment my T420 drives at 1080HD, Though nice, I intially bought it for real estate.
    I'm not bothered if I don't get 4k Res but half the output would be nice!
    I don't take my laptop out much, It sits on the table.
    I don't play games.
    Screen size doesn't matter
    Don't need fancy graphics card, not essential for music software
    Express Slot would be nice but not essential.
    Quad core because its better?? i5-i7 don't care
    Defintely a machine with no throttle-heat issues that could cause Latency spikes to my audio.
    I have been looking at t430/t440p/t450/t460/t470/t480 T550/W540/541
    Finally I have been getting on fine with my T420 i5-2520 @ 2.50Ghz, 16gb, the tech is a little old now, had it for 8yrs.
    Don't want to spend anymore than £700
    Thanks!
  2. User32
    User32 Notebook Evangelist
    Coreboot your T420 and drop in a ivy bridge i7, and then call it a day.
  3. t61jaws
    but you make it sound so easy?
  4. User32
    Then get a T430 or if you can afford it, a P50.
  5. 95bat
    95bat Notebook Enthusiast
    If screen size doesn't matter and its mostly on the desk, buy a desktop. That is much easier to control thermals, is probably cheaper, and you can customize it a little more.
  6. t61jaws
    can a t430 do 32gb ram?
    I know i will have to take it around, so mobility is important. By the quality of replies I'm getting, it wouldn't be a suprise if someone advises me to buy a car to transport the desktop. :rolleyes:
    I posted in notebook Lenovo forum because I want Lenovo geeks to fire off some suggestions on the basis of my post. If I could afford a p50 I wouldn't be asking in this forum. But thanks for your time.
    Kind Regards.
  7. custom90gt
    Any of the newer thinkpads with the quad core mobile processors should be a worthwhile upgrade over your current setup. They can support 32GB of ram. My biggest concern is I don't know how great their DPC latency is, it's something I've never really looked into but know it can be an issue when you're working with music. Even a quick google search (sorry not much time on my hands) doesn't show a whole lot of DPC related info for the newer T series laptops.
    Starlight5, Vasudev and katalin_2003 like this.
  8. t61jaws
    appreciate that, I know shared graphics is better than dedicated for a stable system. Though I heard most gaming laptops are up for the job too.
    If i can just choose between 3 contenders I would be happy.
    Ok so far I got
    1 Quad core = 32gb ram
  9. t61jaws
    I have gone with the t480 i7 16gb ram
    Vasudev and custom90gt like this.
  10. ZaZ
    I think that's a good replacement for the T420.
