my fn key stopped working randomly... any way to adjust brightness?
Discussion in 'Sager and Clevo' started by theorist, Nov 17, 2008.
  1. theorist
    theorist Notebook Consultant
    hi. i have a sager 5791 and it the fn key just stopped working yesterday. i'm not sure why though.
    is there a way to adjust the brightness without the fn key? also possible reasons why the fn key stopped working? thanks.
  2. mr__bean
    mr__bean Notebook Evangelist
    Look in the vista mobility center. Press start and type mobility in the search box to find it.
    This is assuming your running Vista.
  3. zmatin
    zmatin Notebook Consultant
    There is usually a software solution to adjusting brightness, whether it's through your video card's driver/settings under control panel (or equivalent under whatever OS you're using).
  4. zfactor
    zfactor Mastershake
    in the power management section in control panel
