My first razer blade
Discussion in 'Razer' started by Gianlucadbl, Mar 23, 2019.
  1. Gianlucadbl
    Gianlucadbl Notebook Guru
    Throttlestop: -145mv CPU (both), -50mv iGPU, Core to 38 38 36 36 35 35. stability test all perfect. temperatures? always the same, up to 84 degrees in 5-10 minutes of play with RE2. Despite all this the fps have remained unchanged, all very high. I don't know what to do, practically I can't play, or I always have to be very careful
    Inviato dal mio iPad utilizzando Tapatalk
  2. Gianlucadbl
    Finally!
    Lower set cores, undervolting cpu -130mv, I set multiple profiles on throttlestop, with safe profile switches when too high temperatures are reached.
    The performance remained the same on the external monitor with fixed 75fps as before, later I'll try on the razer monitor. we hope well!!
    the max cpu temperature was 80-81, but only spikes.
    most of the time below 76 degrees.
    All at max settings
    https://ibb.co/QpTkdd0
    https://ibb.co/X8w9DSn
    This without external monitor:
    https://ibb.co/Cw8v8Pw
