My First Hard Boot on M17x - Question
Discussion in 'Alienware' started by monkey123456, Sep 20, 2009.
  1. monkey123456
    monkey123456 Notebook Consultant
    Hi Guys -
    I just had to my 1st hard reboot with my new M17x. I was trying to use wordpad and save to a disk. And it just wouldnt close, even in task manager it would not close. Then I tried notepad, which frooze then to. Then I tried to eject the disk, when right clicked on the drive, it frooze then to.
    Question: Is there a reason why this did this? Is this a windows problem? I know wordpad is junk, but didnt think it would freeze up on me and make my computer all weird.
    Note: I also had like 15 internet explorer pages up as well, the 32 bit version of IE. Since I have a 64 bit processor, should I be using the 64 bit IE? Could this of caused this?
    Thanks Guys
  2. phonics2
    phonics2 Notebook Guru
    Welcome to the wonderful world of windows lol.
  3. Purlpo
    Purlpo Notebook Evangelist
    You should use 64-bit IE for sure. Heck you shouldn't use IE at all, try Firefox or Opera. I remember trying to use 32-bit internet explorer the first time I had a 64-bit system, and it got all messed up.
  4. EviLCorsaiR
    EviLCorsaiR Asura
    Whether or not you should use 32-bit IE depends on whether or not you have a 32-bit operating system. To check whether you have 32-bit or 64-bit, go to Control Panel, then in Classic View click on System. Under the 'System' area in the middle, right under processor information it should say either 32-bit Operating System or 64-bit Operating System.
    If your operating system is 64-bit then you need 64-bit IE. If your operating system is 32-bit it will only run 32-bit IE.
    As he says, you shouldn't use IE at all. It's perhaps the worst internet program out there. I'd recommend Firefox.
  5. monkey123456
    Thanks guys, i was so confused on the IE. I have 64 bit OS.
    This may explain to my other post about Java installation giving me a Blue screen. I installed the 32 bit, I never could figure out what was the problem. So I reinstalled the 32 bit java and worked??? But I guess I will have to unistall the java once again to get the 64 bit java.
    Thanks guys once again
  6. Encephalon9986
    Encephalon9986 Notebook Enthusiast
    You forgot Google Chrome. Love that browser
  7. lordqarlyn
    lordqarlyn Global Biz Consultant
    Yep, Windows is prone to periodic freezing. Sometimes I hafta wait a minute before it releases control....
  8. Glzmo
    Glzmo Notebook Deity
    Especially with Nvidia videocards/drivers.
