My first coffee spill
Discussion in 'Panasonic' started by ysz, Dec 19, 2017.
  1. ysz
    ysz Newbie
    So I spilled coffee on my CF19 for the rist time at Starbucks. No sugar. Just a splash of espresso. I wiped what I could around and under keys with a paper napkin. Other than that should I worry at all? Bother to use distill water to try clean coffee under keys? Obviously I am typing this from CF19 :)
  2. aaronne
    aaronne Notebook Evangelist
    isopropanol alcohol (higher % is better because evaporate faster) and good luck! :rolleyes:
  3. User32
    User32 Notebook Evangelist
    Jesus Christ what are you doing, OP don't do this, anything alcohol will damage the plastic. Leave and go back to the Alienware forum with your "advice", you'll damage someone's Toughbook.
    Just rinse it off with plain or distilled water, if you don't have a backlit keyboard that is.
    Stop editing my posts, toughasnails. You know damn well that "jesus christ don't do this" is not offensive at all.
    Kent T likes this.
  4. aaronne
    isopropanol alcohol isn't harmful on plastic on gum, what did u buy?
    a discount one?
    Here one of the right one
    https://www.amazon.co.uk/500mL-Phar...698725&sr=8-1&keywords=isopropanol+alcohol+99
    Shawn likes this.
  5. ysz
    ysz Newbie
    Thanks aaronne ! Should I be in a hurry with that? I never serviced a laptop like that
    Nope, I have regular one. No backlit nothing
    What will happen if I just let it be ? Keys can glue or something like that?
  6. aaronne
    How many sugar in espresso? :D that is dangerous! LoL, just don't start until you're sure to dried it well
  7. Shawn
    Rubbing alcohol or aerosol Electronic cleaner will work fine. I have cleaned many keyboards with either.
    I doubt any coffee got inside the CF19.
  8. ysz
    ysz Newbie
    No sugar! :)
    aaronne likes this.
  9. aaronne
    really good! more "original" taste for your mouth and less sticky for your keyboard :D
    ysz likes this.
  10. BaRRmaley
    BaRRmaley Notebook Deity
    There is nothing sensitive to coffee under keyboard :)
    Just wash kb under normal water jet. I also use soap usually.
    Toyo likes this.
