My car vibrates when I drive
Discussion in 'Motorized Vehicles' started by The Fire Snake, Sep 22, 2009.
  1. The Fire Snake
    The Fire Snake Notebook Virtuoso
    Over the last couple of months when I drive my car vibrates a lot(can feel the steering wheel shaking and can see the passenger seat moving). I was told by my friend that this is caused by the wheel balance being off. Does any one have any idea?
  2. Sodium
    Sodium Notebook Enthusiast
    get the wheels aligned, and balanced
  3. houstoned
    houstoned Yoga Pants Connoisseur.
    sounds like a suspension or wheel problem. i would definitely start with the wheel/tire and get them balanced and then aligned. check yur rims to see if any of the weights came off or if u see a bend in yur rim.
  4. Syndrome
    Syndrome Torque Matters
    Yeah, balance, Could also be your hubs.
  5. aan310
    aan310 Notebook Virtuoso
    tires may be cupping
  6. Tinselworm
    Tinselworm Notebook Deity
    is it a diesel?
  7. K-TRON
    K-TRON Hi, I'm Jimmy Diesel ^_^
    Can be wheel balancing. Go to a tire place, they can individually put your tires on a machine to check that they are balanced.
    You may also want to grease up the ball joints on the steering and front end.
    If your car is older, maybe one of the rubber engine mounts has deteriorated, causing this excess vibration
    K-TRON
  8. millermagic
    millermagic Rockin the pinktop
    Could also be brake rotors, especially if you live in the "rust belt"
  9. houstoned
    if yur brake rotors and/or brake pads are worn out. they could produce a vibration from the metal on metal contact, but it will only vibrate during braking. if this is the case then check yur rotors and pads. easy way to check to see if yur rotors are still fine is to look for deep scratches (from worn brake pad) or rust ON yur rotor's surface.
    i was gonna suggest hubs, but he didn't really mention any aftermarket wheels. if u do have aftermarket wheels, yur car might be hub-centric and the wheel itself is not seated correctly, due to hub/wheel compatibility.
  10. millermagic
    Let me take a picture of mine. There are pieces missing along the outside edge from the rust. Really throws the balance off.
