My 11' 13" MBP gets very hot and noisy instantly since ElCapitan HELP
Discussion in 'Apple and Mac OS X' started by NYCtech, Nov 25, 2017.
  1. NYCtech
    NYCtech Notebook Consultant
    Please please help me.
    At first I thought it was my hd3000 GPU was so out dated it couldnt handle 480p video on youtube in a small window. Then I noticed the fan would go over time. Since ElCapitan its been near maxing out the 4GB of RAM as thats what ElCapitan and Sierra are instructed to do, so Chrome has its helper, Firefox has up to 4 helpers at a time, all choking up the ram, but that doesnt explain why Im getting so hot as my CPU is NOT getting above 10% usage. I only ever have a browser open, no other apps.
    Any theories please?
  2. Arrrrbol
    Arrrrbol Notebook Evangelist
    They call it ElCrapitan for a reason.
  3. Danishblunt
    Danishblunt Notebook Prophet
    The HD 3000 should be able to even handle 1080p no problem.
    Your CPU and GPU are the same chip. Also if you're watching a movie then your CPU will get warm, also, in your case, i'd say you simply need to repaste your macbook. Lucky for you your model is really easy to repaste.
  4. NYCtech
    But it occurs even just web browsing non videos.........
    So you think it needs a new thermal paste of the cpu to the contact?
  5. NYCtech
    Are you saying what i am thinking, El Capitan and Sierra are performance hogs?
  6. Arrrrbol
    Yes, especially on older systems it causes performance loss. Upgrading to 8GB of RAM might help you a bit though, as will a repaste as Danishblunt suggested.
  7. NYCtech
    Thanks mate. I just dont see how ram can cause my system too heat up so much. I wish there was a way to turn off this USE ALL THE RAM FOR THE SAKE OF IT, BS that Mac introduced.
    Is it possible to go back a few OSX's and if so, which one was just prior to this RAM must be used policy?
    Is thermal pasting hard on this system, I presume ifixit has a tear down.
    The thing is the battery lasts 45mins, it need $100 on Ram, it need $100 on a battery, and it really need $100 on a HDD. The laptop is prob only worrth $400 to sell. Would selling it and using the $700-800 to buy something else be a better path? The latter unibody MBP 13" machines resolved this heating issue some how.
  8. Arrrrbol
    The RAM will not help with heat, but it may improve performance.
    Honestly, all of the Macbook Pros have overheating issues by default. Often these can be improved with a repaste, however in my view the ventilation design is inadequate as it does not have a dedicated intake for the fan. This is not at all helped by Apple's fan curves which, in an effort to keep the laptop silent, do not increase the fan speed until it is already over 90 degrees. The old unibody designs can be made to work, but the 2016 model is atrocious for cooling and stands no hope of being improved much.
    In my opinion it's not worth spending that much keeping it going. Save your money for a few weeks/months and sell it. Unless you really wan't Mac OS i'd suggest looking at more capable machines - unless you are willing to go for something like an iMac or even an old Mac Pro (pre trashcan) as they have much better designs on the whole. Even the iMac can overheat though, the 2014 5k ones especially.
  9. NYCtech
    The CPU load is a constant 30%? Really, they design an OS to run at 30% cpu?
  10. NYCtech
    Haha no I rather have a MS Surface Book 2, but dont have the money for it hehe.
    Could I get anything better than this old MBP, used for $800 NZD
