MXM gpu upgrade kit for a ThinkPad P70?
Discussion in 'Lenovo' started by sicily428, Jun 18, 2017.
  1. Sammamish
    Sammamish Newbie
    I'm confused?
    Can a P71 GPU be upgraded?
  2. sicily428
    sicily428 Donuts!! :)
    yes, it uses mxm gpus
    Sammamish likes this.
  3. ijozic
    ijozic Notebook Deity
    Well, yes and no. Yes, it can be upgraded, but apparently only with those cards Lenovo whitelists which in practice are those Lenovo OEM cards that are available for the P71 (i.e. P3000M, P4000M or P5000M). So, you can't upgrade to a Geforce card or to a newer Quadro series card (e.g. if the future releases are of compatible design) or even to a compatible Quadro card from another OEM (though if this whitelisting is based on the vendor and hardware ID's in vBIOS only, these MIGHT become hackable; might because the Pascal vBIOS is encrypted and still isn't cracked I think).
    On the other hand, it has a TB3 port (or two of them), so using an external GPU for upgrade should be possible.
    Sammamish and sicily428 like this.
  4. rlk
    rlk Notebook Consultant
    Unfortunate; I'd really like to be able to put an AMD card from the same generation (W7170M) into a P70.
  5. sicily428
    some news from Eurocom :)
    http://forum.notebookreview.com/thr...a-precision-m7710.804833/page-3#post-10590681
    did you test clevo p750dm2?
    thanks for these infos :)
    I know that MSI 16L13 uses also a MSI gtx1060 mxm 3.0b. Does P5000 work with tornado f5 ?
    wow! those P2000/P3000 for tornado f5 are awesome :)
    what about that p3000 for a p750dm?
    wow! these news are great! :D
