MX14 and NotePal U2 cooler with two fans
Discussion in 'Alienware 14 and M14x' started by Rixact, Nov 17, 2011.
  1. Rixact
    Rixact Newbie
    Hey there. New to the site. I have had my MX14 for a few months and never really played anything on it that would stress the machine. Since Skyrim came out I have been playing it a decent amount, though. My gpu is reading about 64-65C while playing. I decided to order a cooler. This is the actual one I ordered: NotePal U2 - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply. My question is where I should place the fans to get the best results. I believe they should be under the two vents on the bottom but I'm not sure as I'm pretty new to this. Any information would be helpful. Thanks.
  2. sulliboys
    sulliboys Notebook Enthusiast
    I put both of mine down in the center of the notebook (one on top of the other going up under the keyboard and trackpad). Not sure if this is best, but it always cools where it is hot there. I believe that the gpu/cpu are close to there and it keeps the bottom cool to the touch. The ram has all the cooling it need and the fan is just intaking cool air there so ti doesnt really make a difference if you put it in those too places. please correct me if I'm wrong.
  3. Jovan for PREZ
    Jovan for PREZ Notebook Consultant
    If you put the fans inside the left vent, it will blow in cooler air for the laptop to cool itself with. So I would put one on each vent, because although the RAM stays cool enough, it goes straight into the rest of the case.
  4. feroztier
    feroztier Notebook Enthusiast
    Hey guys i just ordered the U3 since i cant find U2 anywhere in my place, so i want to put 2 of the fans on the fans, but one more where should i put it ? Just in the middle of the machine ?
  5. CGSDR
    CGSDR Alien Master Race
    The only reason I bought a cooler (CM Notepal U2) is because of the high CPU temp, the GPU seem to be very stable, and I also notice that if the CPU's temp increase, the GPU temp is also increase and vice versa. And it does help a few degree, but after I turn the Turbo Boost (Which can be found in the BIOS) off, it's even able to reduce like another 5C-10C on top of the cooler effectiveness, so it's like 7C-15C when you combine it. Since I disable the Turbo Boost, the highest temp I ever see is 87C as before I even get the cooler, I used to reach 99C.
    I got mine from Amazon, and you can also get one (in fact there're tons) on eBay, new or second hand alike, the third fan should be place the the bottom where the subwoofer is? Because if there's a hole, mean you can use it for venting as well, although it is not that large but at least better than none at all.
  6. Fallout4
    Fallout4 Notebook Consultant
    I just use the CoolerMaster Notepal U2 stand rather than the fans. It allows the laptop's own fan to draw in air more efficiently.
    I think using the two external fans will just end up blowing a bunch of dust into the laptop.
  7. Rixact
    Rixact Newbie
    I’m running the i5 cpu so I don’t think heat is as much of a problem as some people are experiencing. The cooler has yet to arrive so I’m just guessing that the air will be blowing toward the laptop and didn’t want to push air somewhere I shouldn’t. The vent on the left seems clear that it is released by the vent on the back of the machine. I do not think there is a fan on the vent on the right though. Is this correct?
  8. CGSDR
    Yes that correct, and on the right, it is just a design vent, if you open the case you will see that under that empty vent lay the 2 slot RAM. For me I position each fan on each vent so then on the left it would help pump more air in while the right it help cool the rest of the component as that right side there's no other way for the air to get out so it will help keep it cool down.
  9. Rixact
    Rixact Newbie
    Thanks for the help, everyone. I just set the laptop up on a couple of iced tea caps until the cooler gets here. Just raising it that little bit seemed to keep it cool. After playing Skyrim for two hours the cpu and gpu were only in the low 60C's.
  10. Rixact
    Rixact Newbie
    Hey everyone. Just wanted to follow-up with this post rather than make a new one. I've been loving my MX14, works great for me. I have recently got into SWTOR and enjoy playing it. There is a bit more stress on the system with this. The CPU monitor I have is showing a max of 80C on both cores, when I alt tab out it is showing about 68C as current temp while the game is running. The video card temp monitor is showing around 61-65C.
    So, I'm looking for a better cooler than the Coolmaster U2 that I have now. What are some options for higher end coolers that work well with the MX14?
    Thanks again
Similar Threads - MX14 NotePal cooler
  1. XiCynx
    7
    1,132
