MultiBooting, EasyBCD and Recovery Partition..
Discussion in 'Acer' started by kisetsu17, May 7, 2009.
  1. kisetsu17
    kisetsu17 Took me long enough
    Hi all.
    So I'm thinking of installing XP alongside my default Vista installation and I've got a pretty good idea how to do that..just that there are some questions in my mind..
    First, since I have two partitions (One ACER and one DATA) i wouldn't need to shrink my Vista drive, right? I just have to set-up a 'neutral' partition where I would put in files that I want to share between XP and Vista, right?
    Second, would using EasyBCD and/or installing another OS and/or using Startup Repair (just in case) ruin my recovery partition or something? I remember in my old Lenovo laptop that when I used Startup Repair it somehow managed to screw my recovery partition and made it show up in My Computer..
    Lastly, if ever I decide to use my restore disks, would it restore just the Vista partition or both of them?
  2. AcerAspire2930
    AcerAspire2930 Notebook Enthusiast
    Backup MBR (HDHacker)
    Backup Recovery Partition (Paragon or Symantec)
    MBR contains custom Acer info that is needed for ALT+F10 to work
    Hidden Partition contains Acer Backup.
    You may want to backup your Vista Activation too so you can install a fresh clean copy :)
  3. kisetsu17
    Those programs will be all I need to restore the recovery partition and the MBR at the same time, would it be?
    Can you give me a run-through on how to do those things step by step? Just the backing-up part, and how I should restore them i.e. should I restore after I install XP and reinstall the Vista bootloader, or something?
    I found the multiboot guide from the Windows OS and software section, and I thought it was as straightforward as that.
    Also, do I need to mess with the SATA modes in my BIOS? I remember reading something like that, and currently I have mine set in AHCI mode, and whenever I try to boot in IDE mode it gives me a BSOD. So, how to go about that? :D
    PS I do have my activated Registration key for WinVista under my laptop, do I still need to back up the activation stuff?
  4. AcerAspire2930
    OK. Last first...
    A:
    When I did a clean install of Vista from a Vista DVD I entered my Key (under laptop) and all went well...
    ...until the activation check once Vista was up and running. My key required me to phone (manually activate) M$.
    Nothing dodgy. It's just that the key on the base of our preinstalled Vista's is just our unique number. The laptop preinstalled Vista probably has a VLK.
    Anyway, backing up the Activation allows you to restore the activated state after installing Vista from a Vista DVD.
    hxxp://directedge.us/content/abr-activation-backup-and-restore
    http://forum.notebookreview.com/showthread.php?t=120228
    Will guide and advise you on backing up your Vista Factory Installed Activation.
    A:
    I have no idea :D
    The BSOD is not good for boot up so if changing the BIOS to default will cure that then do so.
    When changeing BIOS settings be sure to boot back to your OS and not to DVD just to check that the OS is cool with the change.
    A:
    The MBR backup is important as installing an OS will overwrite the custom info writen there by Acer. This info allows D2D eRecovery.
    hxxp://dimio.altervista.org/
    Navigate this web address to find HDHacker :)
    You can restore the MBR after installin your OS from CD/DVD.
    Now, multi boot systems require a Partition Table Editor.
    PTEDIT32.EXE (runs in windows)
    I'll get back later but work beckons... :)
  5. kisetsu17
    Cool, thanks, will wait!
    In the meantime, I'll try checking out the links you gave me, after all it won't be until I get home that I'm gonna try this. :D
  6. kiriakost
    kiriakost Notebook Deity
    I am watching this thread with great interest ... :)
    But I like to point out , that every specific steps - actions , of backing up files .
    Must be double tested , many software options they do the backup , but they do not restore as it was planed .
    I never promote solutions , that was not totally tested on my laptop , as 100% working ones !!
    Thats why I advice people, getting a second HDD , and experiment with it .
    The cost its low , and you can go back , with out hassle .
    The spare HDD , can serve with one external USB box , as alternative storage , if everything go well .
  7. kisetsu17
    I do have an external enclosure, but no extra HDD. -_-'
    Well, all I have right now is an extra partition, being D: on my computer without any data written on it, would that be all I need or something?
  8. kiriakost
    I would suggest , to explore the ACER related forum , for a week or more .
    Many people ... the same needs ... everyone ends to use the very few specific ways , that they are exist .
    Use the search button , and read as much you can .
    If you end up having specific questions , we will help gladly.
  9. gazzacbr
    gazzacbr Notebook Evangelist
    get an external drive. acronis true image is good partition backup prog but not free. d: backup is not a backup. you always need external images of your partitions and copies of your personal stuff. just the same as 2nd internal discs are not backups. you need to think of turning on your computer (laptop or desktop) and the hard drive catches fire. d:drive backups are no use. as kiriakost says, experiment on spare small (and cheap) disc.
  10. AcerAspire2930
    Hi again Notebook Geek, ready to get back on your roller-coaster :)
    I'll start by saying that every step has the potential of destroying data. So the user posts above should be noted for their wisdom and advice.
    I'll acknowlage that my method may leave out vital steps that I either forgot or was unaware of.
    This method was used on an Acer Aspire 2930 LXART0X176. BIOS V1.17 runing from mains supply.
    It had been returned to factory state using Acer eRecovery Management befor procedure had begun.
    The MBR was original as purchaced and contained Acer's custom data to enable D2D with Alt + F10.
    There are three partitions with two visible to Windows Vista Home Premium.
    Partition (0) = sda1 = PQSERVICE = ID27 = hidden = inactive = 10GB = Acer eRecovery Restore Partition.
    Partition (1) = sda2 = ACER = Visable = Active = C: = This boots Windows Vista Home Premium which can be restored using the backup image on Partition (0) above.
    Partition (2) = sda3 = DATA = Visable = inactive = D: = Untouched by eRecovery Restore Process.
    Windows Vista Home Premium is running smoothly and all internal devices are functional.
    I will try to use free tools to complete the task.
    STEPS:
    1. Backup MBR
    2. Backup MS Windows Vista Home Premium Activation.
    3. Backup Partition (0) the eRecovery partition.
    4. Deciding what to do with the hard drive partitions.
    5. Installing an OS or Multiboot option.
    6. Backup the new installation.
    7. Restoring to Factory state.
    8. Restoring to Custom Installation.
    This is a time consuming task so I'll start with the first 3 steps.
    1. Backup the MBR.
    I use Dimio's HDHacker as it's easy to use and runs in Windows. It produces a DAT file. This file may be usable with DOS based MBR utilities but HDHacker require Windows and must be run from the local machine. You can not use it from one PC to fix another.
    Extract all files to desktop and right click HDHacker(.exe) then select "Run as administrator"
    Under "Drive to operate" select the "Physical Drive (MBR)" radio button
    In the drop down box that now appears along side "Physical Drive (MBR)" I leave a 0 as it relates to sda1 my harddisk
    Under "Select sector" I leave the default values of:
    "First Sector (MBR)" radio button selected.
    "Number of continuous sectors to read" = 1.
    Under "Read commands" click "Read sector from Disk"
    The "Sector Image (MBR HardDisk0)" will display the contence of this sector for you to view. You'll notice the word "Acer" a number and then "System". You can not edit this information it is only shown for information.
    Under "Write commands" click "Save sector to File"
    The default Save Name is "MBR_HardDisk0.dat". You should change the name in the dialogue ensuring the extension is ".dat" for easy assocation on restoring using HDHacker later. I chose "MBR_ACER2930.dat" and typed ".dat" too.
    That's your backup of the MBR completed, save both HDHacker and your MBR dat file on an external device.
    Both HDHacker and the utility ABR, which is used to backup activation, can be run from a USB Pen Drive.
    There is a guide localy here that shows how to use ABR.
    The Home Page is hxxp://directedge.us/content/abr-activation-backup-and-restore.
    hxxp://ping.windowsdream.com/
    PING
    PING (Partimage Is Not Ghost) -- Backup and Restore Disk Partitions
    I used PING Stand-alone ISO without addons. For laptop users having difficulty with the backslash "\" symbol when using PING:
    1. Enable Numbers Lock (Fn + NumLk). You can not use the numbers along the top of the keyboard to input ALT Codes.
    2. Press and hold Alt key and type whilst holding down the Alt key numbers 9 and 2 that are embosed in the same colour as Fn. (9K)
    3. Where the cursor was should appear "\" (If the screen changes reboot (ctrl + alt + del) and start again typing correctly)
    Google "alt codes" for more info.
    Create a folder on D: called PING and reboot. This folder is case sensitive. Ping is not pIng is not PING. PING is PING.
    Boot PING CD (Press F12 for boot menu and select CD/DVD)
    Navigate with keyboard.
    Follow on screen prompts:
    Press Enter
    OK (Enter)
    Arrow down to select "Reboot the system" OK (Enter)
    Arrow down to select "Local disk/partition OK (Enter)
    Arrow down to highlight"[ ] sda1 (27) (BOOT,D2D,EFI,FACTORY,Program Files,...)"
    Space Bar to select "[*] sda1 (27) (BOOT,D2D,EFI,FACTORY,Program Files,...)"
    OK (Enter)
    Arrow down to select "sda3 (HPFS/NTFS) (Lable: DATA)" OK (Enter)
    This part require you to type the backslash "\" the keyboard code page may be set to display "<" when the backslash is typed.
    Try the "#" key.
    [Alternativly use Alt + 92 using the number pad keys (Alt +9k)]
    Type "#PING" (case sensitive) so the dialogue box look like:
    \PING
    OK (Enter)
    "Create_New_Image" is already highlighted so press enter (OK)
    Type a name:
    AcerAspire2930_D2D
    OK (Enter)
    We will not be making an incremental backup. "No" is highlighted and we can press Enter to continue (OK)
    Leave the default "gzip" compression and press enter (OK)
    Partimage OK (Enter)
    We'll take the default action "No" and not reduce the fiesystem. OK (Enter)
    We must now wait for our backup to complete...
    The PC should reboot and start Vista. You can check the backup on D.
    I am testing this method whilst writing so it's time to pause now and continue later. Feel free to add or comment as you wish...
    ...later :)
  11. kisetsu17
    Thanks for the effort you're putting into this. :D
    I was trying my own (risk it all) method to do this and there's some difficulties I keep coming at. Here's what I do:
    1. I backed up the MBR with the Acer thing, saved as default filename.
    2. I used Disk Management in Vista (right-clicking My Computer>>Manage) and created another extra partition from my D: drive, so I had three (C: Acer, D: DATA, G: XP)
    3. I restarted the computer, and switched (via the BIOS) the SATA mode from AHCI to IDE, since XP installation would BSOD when I leave it at AHCI.
    3. I installed Windows XP Pro in the XP partition, waited about 40 minutes and then logged on as Administrator.
    Here's when I think I don't get right:
    4. I installed .NET Framework 2.0 and EasyBCD.
    5. I open EasyBCD, and added Windows XP and switch the drive to G:, since that's where I installed XP
    6. I opened HDHacker and wrote my backed-up MBR to disk.
    When I restarted the notebook, it gave me a BOOTMGR IS MISSING, blah blah. So I pressed enter, but it brought me to a boot menu with TWO entries named Windows XP Professional. I chose one, and then logged on again, and tinkered once again with EasyBCD. I remember choosing the option to reinstall the Vista bootloader. I restarted, then when I got to the boot screen I was given both Vista and XP, but when I chose XP it said something about /NTLDR missing, and I have to use a Windows disk to repair it. I just snapped and reformatted the XP partition altogether, since I got to this about thrice already! I just don't know what I am doing wrong. Haha. What should I do first, add XP to the MBR entry or restore the MBR backed up by HDHacker?
    EDIT: Also, it still bugs me that the AHCI thing and the IDE thing have to be switched when booting Vista and XP, respectively. I can't seem to install the AHCI drivers when I was in the XP environment, says I do not meet the minimum requirements.
  12. AcerAspire2930
    Oh yeh! BSOD with XP and AHCI enabled in BIOS.
    I bet that's so Vista stays put on our laptop and we don't downgrade to the better XP :lol:
    Found this:
    hxxp://www.msfn.org/board/index.php?showtopic=107504
    Slipstream AHCI drives into XP install CD
    On the installation partition issue, I don't install an OS to anyother partiton other than C.
    The MBR tell's the system which partition to boot:
    0,1,2,3
    Then the partition that boots desides how to boot.
    When you installed XP
    The MBR said goto Partition 1
    and then XP said once there goto Partition 3 (G)
    C is boot D is DATA E is DVD and G is the new primary, system partition.
    Restoring the MBR probably was ok as the boot drive is still 1
    Adding G to EasyBCD (don't know it) was probably the problem as G isn't bootable, it's just the system drive for XP.
    [EDIT]EasyBCD seems to write to the MBR to this would kill Alt+F10[/EDIT]
    The option to boot the OS (XP) on G drive is located on C drive in the BOOT.INI file.
    So EasyBCD should just point to C.
    I like to install Windows OS's to an Active Primary Partition, C.
    I'll hide all other primary partitions which will allow an installation Windows CD to boot without asking to "Press any key to boot from CD". It asks this if it notices an OS installed and probably helps with unattended installs with the CD/DVD as first boot device.
  13. kisetsu17
    So this means that upon installation I should just point Windows XP to C: in EasyBCD? Also, would restoring the MBR with the Acer Alt+F10 before putting in the entries be a good idea? or is that the right one?
    Wow, this is turning out to be some hassle, more than I though it would be. haha. And here I was just thinking of installing a new OS just so I could try if my failure in overclocking just can't work with preinstalled Vista--now I'm just thinking of installing Windows 7 RC, perhaps that would not be much of a hassle.
    ...of course not before I conquer this stuff though! Hahahaha.
  14. AcerAspire2930
    I don't know what EasyBCD does and to what. If it loads to the MBR then you can have it take control of all the partitions on the harddisk including PQSERVICE. There would be no need, I think, for the Alt + F10 BIOS setting or D2D enabled in the BIOS as EasyBCD could control booting from PQSERVICE. The partition ID may need to be changed to 07.
    For now lets just install one OS using the second partition.
    We have a backup of the Acer MBR and we have the PQSERVICE partition intact.
    We can leave the third partition alone and simply install to the active windows partition.
    The intergration of the Textmode iaStor AHCI driver has allowed be to start XP installation without BSOD.
    I'm now at the partition list for my laptop:
    238474 MB Disk 0 at Id 0 on bus 0 on iaStor [MBR]
    F: Partition1 (PQSERVICE) [NTFS] 10245 MB (1602 MB free) *just a note to myself
    C: Partition2 (ACER) [NTFS] 114116 MB (94699 MB free) Highlight this and delete
    D: Partition3 (DATA) [NTFS] 114113 MB (69836 MB free) I have loads of stuff on here :)
    I don't want to setup Windows XP on C:, D:, or F: as that'll be dual boot. I want Windows XP on C: so I'll delete it!!!
    Press D then Enter then L to confirm.
    Now I have Unpartitioned space which I'll select (down arrow) and confirm I want to install XP here by pressing Enter.
    (I could reboot now, press F12 to boot from CD and see if the boot CD ask me to press a key to boot from CD - It won't as Vista has sortof gone!)
    Format using NTFS and continue with the install.
    You didn't here this from me but you could use PTEDIT32.EXE and change the boot ID's of the partitions you have...
    ...you said you now have four partitions.
    1 = ID27 = PQSERVICE = Boot Status 00
    2 = ID07 = ACER WIndows Vista = Boot Status 80 (bootable and 80 makes it C: too.)
    3 = ID07 = DATA = Boot Status 00
    4 = ID07 = Your Label = Boot Status 00
    Using PTEDIT32.EXE in Vista change:
    2 boot status from 80 to 00
    and
    4 boot status from 00 to 80
    I don't want to leave you hanging as PTEDIT32.EXE is windows based and rebooting will leave your PC without a bootable OS.
    XP won't install without the needed Textmode driver being intergrated so untill that is done XP will fail to install (BIOS = IDE to OK).
    But you now have a partition you can install a Windows OS to. Run PTEDIT32.EXE when installed and change ID and boot status to boot back to Vista...
    Still installing XP :)
  15. kisetsu17
    Wait, wait, so you're installing XP and then Vista? Or not? Heheh. I was attempting to install XP hopefully without bothering my Vista installation, or would that be more complicated?
  16. AcerAspire2930
    Lost everything late last night :lol:
    [EDIT]
    OK, you can still read this post but I found the problem :D. I wrote the boot record of Partition C: to the MBR of the hard disk. This is why I got "Disk IO error". I had a look at the BIN/DAT file I wrote to disk (MBR) last night and it's of C doh! So nothing to do with bashing the laptop and all to do with user error - ME. I'm glad about that too :)
    So read on and have a giggle...
    [/EDIT]
    Disk IO error and nothing but corrupt partitions!!!
    My last action was within XP (running AHCI). I wrote a MBR which I could have sworn came off my laptop at some stage but didn't have the Acer string.
    Anyway, rebooting left me with nothing!
    After much tinkering with:
    (Booting from external device such as USB/CD)
    System Commander Utilities (££ Cost)
    Paragon Drive Utilities (££ Cost)
    PartLogic (Free)
    The hard drive came back to life. Then using Paragon's Partition Recovery Wiz I managed to get back PQSERVICE but that's it.
    D: is lost to me.
    I have backup's of all though so the data was not a worry, the Disk IO error was.
    I don't know really why I had that!
    Was it the disk saying "Stop messing with my IDE AHCI settings then rebooting and messing with my MBR which could have been from IDE or AHCI and refferred to a partition config that looked nothing like the actual partition table (PT)"
    Or was it just simply my last action - HDHacker and the mystery MBR...
    Bottom line is an IO error could cost money. Replacement disk or even damage to the mainboard - a lost PC - Warrenty, well, I kinda do these things at my own risk. I am hammering this laptop. The method of backing up the PQSERVICE, MBR should be fine. Paragon, although commercial, does the job!
    I have played with PC's for years and have forgotten the headaches and cost of lost data.
    I should remind myself!!!! :)
    So, only try this if you're happy to loose it all or wait for the task to be complete and a Workable Method Found :)
    That statement is for those who are reading and thinking, "I'll have a go." Have a go but know the risks.
    For those reading with Disk IO error. Sorry :p (I'll help if you need me :D )
    Back to XP or Vista first? It only matters for dual boot. That's one OS booting the other. I don't do that. I think dual boot means either C:\windows and C:\winxp on the same partition or C:\windows and D:\windows with C the main boot partition.
    I'm not sure if XP should be installed then Vista for dual boot or the other way around :)
    How I install multi OS's is one per primary partition with the installed OS hidden and a clean partition active ready to install the new OS to. It doesn't matter which order then. I also use System Commander to choose OS at boot time. I would also partition the drive with System Commander or other boot from CD utility but not Windows!
    Primary - windows
    Primary - windows
    Primary - windows
    Extended - (Linux boot)
    - Linux
    - Linux Swap
    - NTFS
    I would manually hide all other primarys and set active the partition I want to install the WIndows OS to. Linux is a little less fussy. :)
  17. kisetsu17
    Wow, sorry for that IO error man, that got me scared with what I was planning to do this night for my notebook. :D
    How do you "hide" your partition? So I made my XP installer retrofitted with my AHCI drivers (mine's ICH9M, 'coz that's what shows up in Vista's Device Manager) and I'm attempting (or thinking of attempting) to have another go at that. :D
    Anyway, the Dualbooting guide I mainly wanted to follow when I thought of multibooting was the one found here. There's a link that shows how to install XP in a system with Vista installed first.. So would that process be to the demise of our PQSERVICE partition? I was thinking that, since that guide seems to be a general install-another-OS-and-just-that kind of guide, maybe we could make (if there isn't already, my searching skills failed me here) make a guide specifically for Acer systems with the recovery partitions and the Alt+F10 functions still intact.. :D
  18. AcerAspire2930
    Ok, just done a dual boot.
    Factory Vista and the PQSERVICE were both working fine. As you know I had lost D: but that left me with available free space.
    Booted from CD to install XP within that free space (had to format but was part of the XP install).
    Once XP had installed I enabled the Vista Loader with EasyBCD which also wrote to the MBR. I think XP was already an option or became an option on reboot but if not EasyBCD could add it later (Would probably need to install it to Vista too).
    Now Vista boot loader would manage booting to both it or XP.
    Since Vista was still located in the same partition as factory default, loading the factory MBR using the correct backup enabled Alt+F10 and had no effect on Vista still booting it's self or XP. The Factory restore was enabled now.
    Using factory install would wipe Vista but leave XP, although XP would not beable to boot. Installing EasyBCD should fix this but I have not tried that.
    Dual-Boot and having a MBR backup is a nice easy way to run two OS.
    [EDIT]
    Multiboot info from a master
    hxxp://www.goodells.net/multiboot/
    Free :) Tool - Haven't tried it yet
    hxxp://www.partition-tool.com/personal.htm
  19. kisetsu17
    I also did a dual boot! Woot!
    Anyway, the difference though lies in that you can use the Alt+F10 but I can't. What I did was this:
    1. Created a XP install disk with AHCI using nLite. (cool!)
    2. Partitioned my D: and put extra (XP drivers, etc) install files in G: (new partition), left D: alone, where I would install XP.
    3. Burnt and ran XP disk, install went fine, booted into XP
    4. Installed .NET Framework 2.0 (for EasyBCD), installed EasyBCD, added the XP entry in D:, restored the Vista bootloader.
    5. Restarted the laptop, saw the much-anticipated Vista bootloader showing both Vista and XP!!
    6. Booted XP, expecting there would be another hardware something error, but it pushed through!
    7. Restarted and tried Alt+F10, no response. -_-'
    I tried restoring the MBR using HDHacker, and then editing it using EasyBCD to put in the entries, but it would not let me boot XP.. Aw man, such a bummer.
    How did you enable the ALt+F10, then? :D
  20. AcerAspire2930
    Alt+F10 + 3 Partitions = Acer MBR
    I think a hex editor and or PTEdit will be needed to enable Alt + F10 with a modified MBR
    Been trying to get a Boot CD with free utilities, burnt some coffee mats but finally....
    FATxx and NTFS only!
    Haven't fully tested the software yet but I've added a free Partition Manager and DriveImage backup tool to BartPE Bootable CD.
    It may help backup and partition the Acer. More later:
    FOR XP PRO SP2 to SP3 Then To BartPE with EASEUS Partition Master 3.5 Home Edition & DriveImage XML
    1. Copy entire XP Pro SP2 to folder on your hard drive.
    eg: C:\Documents and Settings\User\Desktop\WINDOWS XP AHCI\WINXPSP2
    2. Download Windows Installer 3.1 Redistributable (v2)
    hxxp://www.microsoft.com/downloads/details.aspx?FamilyID=889482fc-5f56-4a38-b838-de776fd4138c&displaylang=en
    3. Slipstream Windows Installer 3.1 Redistributable (v2) into WINXPSP2
    For HELP type: "[PATH TO DOWNLOAD]\WindowsInstaller-KB893803-v2-x86.exe" /? include quotes then add /?
    WindowsInstaller-KB893803-v2-x86.exe /integrate:"C:\Documents and Settings\User\Desktop\WINDOWS XP AHCI\WINXPSP2"
    4. Download Windows XP Service Pack 3 Network Installation Package for IT Professionals and Developers
    hxxp://www.microsoft.com/downloadS/details.aspx?familyid=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
    5. Slipstream Windows XP Service Pack 3...
    windowsxp-kb936929-sp3-x86-enu.exe /integrate:"C:\Documents and Settings\User\Desktop\WINDOWS XP AHCI\WINXPSP2"
    6. Download and install nLite hxxp://www.nliteos.com/download.html
    7. Start nLite and add "C:\Documents and Settings\Use\Desktop\WINDOWS XP AHCI\WINXPSP2" as location of Windows installation.
    8. Ignor presets (next) and Task Selection select Integrate > Drivers and Create > Bootable ISO (You can choose more options)
    9. Insert Textmode Driver (For Acer Aspire 2930 use f6flpy3288.zip "Intel(R) ICH9M-E/M SATA AHCI Controller")
    hxxp://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=2101&DwnldID=17413&lang=eng
    10. Complete the process and go on to create ISO (Mode = Create Image). Label can be ACER. Click "Make ISO".
    That's the Installable CD of XP done with AHCI Textmode driver.
    The Windows Installation files located "C:\Documents and Settings\User\Desktop\WINDOWS XP AHCI\WINXPSP2" have been updated.
    11. Download:
    PE Builder hxxp://www.nu2.nu/pebuilder/#download
    EASEUS Partition Master 3.5 Home Edition hxxp://www.partition-tool.com/personal.htm
    DriveImage XML PE Plugin hxxp://www.runtime.org/peb.htm
    12. Install:
    PE Builder and EASEUS Partition Master 3.5 Home Edition
    EASEUS Partition Master 3.5 Home Edition and DriveImage XML will both be included in Bart's PE Builders Plugin directory. Adding
    driveimage_xml.cab can be done from within PE Builder. EASEUS Partition Master 3.5 Home Edition will be done manually and that is why
    it needed to be installed.
    13. Create a folder "EASEUS Partition Master 3.5 Home Edition" within the plugin directory.
    C:\pebuilder3110a\plugin\EASEUS Partition Master 3.5 Home Edition
    14. Create two new folders within "EASEUS Partition Master 3.5 Home Edition" called "Files" and "System32"
    C:\pebuilder3110a\plugin\EASEUS Partition Master 3.5 Home Edition\Files
    C:\pebuilder3110a\plugin\EASEUS Partition Master 3.5 Home Edition\System32
    15. Copy: (paste each into run box)
    xcopy C:\WINDOWS\system32\BootMan.exe "C:\pebuilder3110a\plugin\EASEUS Partition Master 3.5 Home Edition\System32\"
    xcopy C:\WINDOWS\system32\epmntdrv.sys "C:\pebuilder3110a\plugin\EASEUS Partition Master 3.5 Home Edition\System32\"
    xcopy C:\WINDOWS\system32\EuEpmGdi.dll "C:\pebuilder3110a\plugin\EASEUS Partition Master 3.5 Home Edition\System32\"
    xcopy C:\WINDOWS\system32\EuGdiDrv.sys "C:\pebuilder3110a\plugin\EASEUS Partition Master 3.5 Home Edition\System32\"
    xcopy C:\WINDOWS\system32\setupempdrv03.exe "C:\pebuilder3110a\plugin\EASEUS Partition Master 3.5 Home Edition\System32\"
    16. Open "C:\Program Files\EASEUS\EASEUS Partition Master 3.5 Home Edition"
    and copy all folders and content except unins000.exe and unins000.dat to
    "C:\pebuilder3110a\plugin\EASEUS Partition Master 3.5 Home Edition\Files"
    17. Create a file called "epm.inf" in "C:\pebuilder3110a\plugin\EASEUS Partition Master 3.5 Home Edition"
    hxxp://www.911cd.net/forums//index.php?showtopic=22809
    add
    Code:
    ; PE Builder v3 plugin INF file
    ; EASEUS Partition Master 3.5 Home Edition
    ; http://www.partition-tool.com/personal.htm
    ; !!! NOTE for Windows Vista users !!!
    ; Extract the Windows XP drivers epmntdrv,2.sys and EuGdiDrv,1.sys from EPMSetup.exe using Universal Extractor
    ; Get Universal Extractor from http://legroom.net/software/uniextract
    ; After extraction rename the files epmntdrv,2.sys and EuGdiDrv,1.sys to epmntdrv.sys and EuGdiDrv.sys
    [Version]
    Signature= "$Windows NT$"
    [PEBuilder]
    Name="EASEUS Partition Master 3.5 Home Edition"
    Enable=1
    [WinntDirectories]
    a="programs\Epm",2
    [SourceDisksFolders]
    ; Include all files and folders from the "c:\Program Files\EASEUS\EASEUS Partition Master 3.5 Home Edition" folder
    ; Except the files unins000.dat and unins000.exe
    Files=a
    [SourceDisksFiles]
    ; Include the files from your %WinDir%\system32 folder
    system32\BootMan.exe=2,,3
    system32\epmntdrv.sys=2,,3
    system32\EuEpmGdi.dll=2,,3
    system32\EuGdiDrv.sys=2,,3
    system32\setupempdrv03.exe=2,,3
    [SetupReg.AddReg]
    0x4,"ControlSet001\Services\epmntdrv","Type",0x00000001
    0x4,"ControlSet001\Services\epmntdrv","Start",0x00000003
    0x4,"ControlSet001\Services\epmntdrv","ErrorControl",0x00000001
    0x1,"ControlSet001\Services\epmntdrv","DisplayName","epmntdrv"
    0x1,"ControlSet001\Services\epmntdrv","ImagePath","system32\epmntdrv.sys"
    0x4,"ControlSet001\Services\EuGdiDrv","Type",0x00000001
    0x4,"ControlSet001\Services\EuGdiDrv","Start",0x00000003
    0x4,"ControlSet001\Services\EuGdiDrv","ErrorControl",0x00000001
    0x1,"ControlSet001\Services\EuGdiDrv","DisplayName","EuGdiDrv"
    0x1,"ControlSet001\Services\EuGdiDrv","ImagePath","system32\EuGdiDrv.sys"
    [Software.AddReg]
    ; Add to XPE Start Menu
    0x2, "Sherpya\XPEinit\Programs","Disk Tools\Partition Tools\Easeus Partition Master 3.5","%SystemDrive%\programs\Epm\epm0.exe"
    [Append]
    nu2menu.xml, Epm_nu2menu.xml
    18. Create a file called "epm_nu2menu.xml" in the same place "C:\pebuilder3110a\plugin\EASEUS Partition Master 3.5 Home Edition"
    hxxp://www.911cd.net/forums//index.php?showtopic=22809 use code from 911cd.net
    add (fixed < > )
    Code:
    [i]<[/i]!-- Nu2Menu entry for "EASEUS Partition Master 3.5" -->
    [i]<[/i]NU2MENU>
      [i]<[/i]MENU ID="Programs">
        [i]<[/i]MITEM TYPE="POPUP" DISABLED="0" MENUID="EASEUS"<EASEUS Partition Master>/MITEM>
      [i]<[/i]/MENU>
      [i]<[/i]MENU ID="EASEUS">
        [i]<[/i]MITEM TYPE="ITEM" DISABLED="@Not(@FileExists(@GetProgramDrive()\Programs\Epm\bin\Epm0.exe))" CMD="RUN" FUNC="@Null(@ChangeDir(@GetProgramDrive()\Programs\Epm\bin))epm0.exe">Easeus Partition Master 3.5[i]<[/i]/MITEM>
      [i]<[/i]/MENU>
    [i]<[/i]/NU2MENU>
    The EASEUS Partition Master 3.5 Plugin is now ready so start PE Builder.
    19. PE Builder Source path to Windows installation files: "C:\Documents and Settings\User\Desktop\WINDOWS XP AHCI\WINXPSP2\"
    Custom files and Output (BartPE) can be left at default.
    20. Media output > Create ISO image and choose a name. (Menu > Builder > Options > Volume ID = change to ACER)
    21. Click Plugins to see EASEUS Partition Master 3.5 Plugin in the list and Enabled.
    22. Click Add and find "driveimage_xml.cab" > Open > OK. DriveImage XML will now also be Enabled and in the list. Close the plugin Window.
    Sorry - haven't included how to add AHCI Drivers to BartPE
    hxxp://www.nu2.nu/pebuilder/help/english/drivers.htm
    NOTE: unzip Text mode drivers to:
    C:\pebuilder3110a\drivers\SCSIAdapter\XP_AHCI\f6flpy3288
    and edit TXTSETUP.OEM to only referrance the driver needed ("Intel(R) ICH9M-E/M SATA AHCI Controller") and all required pointers.
    Code:
    ; Copyright (c) 2003-09 Intel Corporation
    ;#    Filename:  TXTSETUP.OEM
    [Disks]
    disk1 = "Intel Matrix Storage Manager driver", iaStor.sys, \
    [Defaults]
    scsi = iaStor_ICH8MEICH9ME
    [scsi]
    ; iaAHCI.inf
    iaAHCI_ICH9MEM            = "Intel(R) ICH9M-E/M SATA AHCI Controller"
    ; iaStor.inf
    ; iaAHCI.inf
    [Files.scsi.iaAHCI_ICH9MEM]
    driver = disk1, iaStor.sys, iaStor
    inf = disk1, iaAHCI.inf
    catalog = disk1, iaAHCI.cat
    ; iaStor.inf
    [Config.iaStor]
    value = "", tag, REG_DWORD, 1b
    value = "", ErrorControl, REG_DWORD, 1
    value = "", Group, REG_SZ, "SCSI Miniport"
    value = "", Start, REG_DWORD, 0
    value = "", Type, REG_DWORD, 1
    ; iaAHCI.inf
    [HardwareIds.scsi.iaAHCI_ICH9MEM]
    id = "PCI\VEN_8086&DEV_2929&CC_0106","iaStor"
    ; iaStor.inf
    PE Builder will add them automatically to the ISO in the next step
    Silly me :)
    23. Click Build to create your ISO (The BartPE directory does not exist so click "Yes"
    There should be no Errors and the only Warnings may be ISO-9660 file name length - probably TXT files too long.
    It's OK to close and Exit PE Builder.
    24. Burn ISO (settings in burner should allow booting of CD - DAO Finalized)
