MSI P65 8RD GPU problem
Discussion in 'MSI' started by Califauna, Oct 1, 2021.
  1. Califauna
    Califauna Notebook Enthusiast
    Three different installations of windows have been tried. (21H1) 19043.928 is the current one.
    DISM and SFC complete. SFC found corrupt files and repaired them. Restart complete. SFC scan is now clean.
    Windows Update is complete.
    Have previously tried two other GPU drivers (the driver automatically installed with windows, and the driver on the MSI website)
    When PC is running, the power light is white, which indicated integrated graphics mode is running. Monitoring the load on dGPU using windows resource montior, I can see that it remains at zero, even when running videos using edge browser.
    When I use windows settings to force dedicated GPU for VLC media player, then play a video using VLC, the light turns orange (indicating dedicated GPU mode for this laptop). However, in VLC the video does not playback correctly (sounds plays correctly for whole video, and first image frame loads correctly when opening, but the image does not change). During this time load in resource monitor on the dedicated dGPU remains zero.
    The temperature reading doesn't go above 55.
    Inserting HDMI cable then switching to 'duplicate screen' causes multiple spikes in the dGPU load (100%, 0%, 100%, 0%). It has also caused two BSD:
    Crash Dump Analysis
    Crash dumps are enabled on your computer.
    Crash dump directories:
    C:\Windows
    C:\Windows\Minidump
    On Sat 10/2/2021 3:13:17 AM your computer crashed or a problem was reported
    crash dump file: C:\Windows\Minidump\100221-6609-01.dmp
    This was probably caused by the following module: watchdog.sys (watchdog+0x3AD0)
    Bugcheck code: 0x119 (0xA000, 0xFFFF8286C713DBB0, 0x1, 0x2)
    Error: VIDEO_SCHEDULER_INTERNAL_ERROR
    file path: C:\Windows\system32\drivers\watchdog.sys
    product: Microsoft® Windows® Operating System
    company: Microsoft Corporation
    description: Watchdog Driver
    Bug check description: This indicates that the video scheduler has detected a fatal violation.
    The crash took place in a Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
    crash dump file: C:\Windows\MEMORY.DMP
    This was probably caused by the following module: watchdog.sys (watchdog!WdLogEvent5_WdCriticalError+0xE0)
      File size:
      30.2 KB
      18
  2. NeXt3R
    NeXt3R Notebook Evangelist
    1050 TI ,.no 1070
    https://www.tenforums.com/tutorials...-accelerated-gpu-scheduling-windows-10-a.html
    this disable + variable refresh rate "if exist"
    win 19043 ,.is latest 1266build or 1237 stable
    try last chipset drivers
    Intel Chipset Device Software Version 10.1.18836.8283 WHQL
    https://www.station-drivers.com/ind...Device-Software-Version-10.1.18836.8283-WHQL/
    // working igpu drivers
    last bios / ec
    the other is the hw problem "here is the chip on the mobo d-gpu"
    ,, it's not an easy fix!
    edit
    and why are you hiding SUBSYSTEM ID ??
    you need in best identical ID for DEVICE / SUBSYSTEM for correct vbios
    and this VEN / DEV look looks the opposite ?? your custom vbios ??
    Califauna likes this.
  3. NeXt3R
    nvlfash + cmd
    NVFLASH64 --version
    here verify real info for bios / if exist recovery
    ,.,or need vbios from MSI support "this vbios is impossible find"
  4. Califauna
    Bios is updated, chipset update with your link has now been tried. Variable refresh rate option does not appear.
    I don't know what you mean here:
  5. NeXt3R
    broken d-gpu -- is need replace motherboard
    send more info from NVFLASH ,,sometimes exists recovery on gpu
  6. Califauna
    Do you mean recovery of the bios?
    What info do you need from NVFLASH to know if recovery of the bios is possible?
    Will reflashing bios void the warranty?
  7. NeXt3R
    nvlfash + cmd
    NVFLASH64 --version
    send only info ,,.not flash ,.,.,.must determine GPU problem !
    ,.,.hwdefect is impossible repair in NVFLASH
    but some info look weird - send this screen from NVFLASH "PM ?" full info !!
  8. NeXt3R
    try AFTERBURNER and negative OC
    determine HWproblem / or only POWER PROBLEM .,or VBIOS support for BOOST clock
    but this need small skill :D
    and still you need fully working igpu ?? / d-gpu - OPTIMUS
    igpu drivers works fully ??
  9. Califauna
    iGPU seem to work OK. The iGPU test in GPUz gives normal temperatures, 1.065v, 8.6 watts, 1050 Mhz. It renders correctly. All software works fine when laptop is in iGPU mode (white power light).
    Underclocking does not fix problem. Connecting HDMI has same effect and the same results from GPUz when testing. Jumps to 1506Mhz (GPU) and 3499Mhz (memory) when loaded up, then they drops to 607 and 405 Mhz after 3 seconds and stay there.
    When using Afterburner to lock the GPU at 1303Mhz and Memory at 3499Mhz, the video plays back correctly, but connecting with HDMI cable results in same behavior as before ( screen on and off, system hanging) and running GPUz tests results in the same behavior (a series of load spikes then a system message that GPUz has been blocked from accessing hardware).
    The details of the bios are: Sign-On Message : GP106 E2914 SKU 30 VGA BIOS IFR Subsystem ID : Blank Subsystem Vendor ID : 0x1462 Subsystem ID : 0x1244 Version : 86.06.6F.00.2B Product Name : GP106 Board Device Name(s) : GeForce GTX 1050 Ti Board ID : 0x005D Vendor ID : 0x10DE Device ID : 0x1C21 Hierarchy ID : Normal Board Chip SKU : 730-M Project : 2914-0030 Build Date : 06/01/18 Modification Date : 08/19/18
    The chip is this one by the looks of it:
    https://www.techpowerup.com/gpu-specs/msi-gtx-1050-ti-mobile-4-gb.b8524
    Can you confirm if reflashing the vbios will void the warranty?
  10. NeXt3R
    send screen from NVFLASH that is, send the screen and not partial information in the text
    try service repair
