MSI P65 8RD GPU problem
Discussion in 'MSI' started by Califauna, Oct 1, 2021.
  1. Califauna
    Califauna Notebook Enthusiast
    I have an MSI P65 8RD.
    When connecting an HDMI cable and selecting 'Duplicate' the following happens
    https://drive.google.com/file/d/1hWjpZ9cHfdjhtHWsnr6jhD9w2HwCjlIZ/view?usp=sharing
    Every 15 seconds or so the mouse freezes then disapears for a couple of seconds, the laptop screen goes black for a couple of seconds. The same thing happens on the monitor connected to the HDMI.
    Refresh install hasb ben done, all drivers automatically installed , then also tried the drivers from MSI's website.
    Same thing with a different (also working) HDMI cable and monitor.
    Dedicated (1070 Ti) and built in graphics are both detected and listed as working.
    Any kind of tests I can do here to find out what the problem is (presumably with the dedicated GPU)?
  2. NeXt3R
    NeXt3R Notebook Evangelist
    internal monitor works normally ?
    drivers 472.12 ?? nvidia
    1070 ?? TI --NO .,,.maxq - no power
    Califauna likes this.
  3. NeXt3R
    test is easy -- MSI KOMBUSTOR
    try D-gpu render
  4. NeXt3R
  5. NeXt3R
    try first
    GPU render on internal monitor - GPUz render test
    latest drivers
    windows update -last update for your windows build
    others repairs is advanced ! :D
  6. Califauna
    The driver I have installed is 472.12 latest from nVidia website.
    This is what happens when checking the load and temps with GPUz (running as an administrator):
    https://drive.google.com/file/d/125_cDl6lf9O9KdyKDKDYZz9UbBn4-sh_/view?usp=sharing
    Sensors in GPUz get data for a few seconds (temperatues, loads, etc.) then nothing. I get a notification that GPU-Z has been blocked from accessing the graphics card.
  7. NeXt3R
    d-gpu problem
    send firs page --gpu info
    for more info about vbios update / hwinfo state
    91C is max for this gpu .,94C slowdown .,,.98C shutdown
  8. NeXt3R
    but render look OK .,,weird
    windows full name ,.,.build --START ,.,.write WINVER
    send info
    edit
  9. NeXt3R
    here is probably OPTIMUS ,.,.must fully works igpu - intel drivers + NVIDIA d-gpu
    and windows basic repair "from upgrade" or badly installed system
    CMD + admin
    DISM /Online /Cleanup-Image /RestoreHealth
    CMD + admin
    SFC /scannow
  10. NeXt3R
    or teamviewer ?? send PM ID + pass
    ,.,.install chipset drivers - here is some next drivers for BUS
    from topic here on forum .d
