MSI GTX 1070 MXM successfully working on Alienware M17X R4 (another socket victory against BGA crap)
Discussion in 'Alienware 17 and M17x' started by D4ddy, Apr 13, 2017.
  1. A-Gits
    A-Gits Notebook Enthusiast
    No, at least nobody i know... Pascal Cards are hard to flash, you need a programming tool (hardware) and enough knowledge to do it yourself. You cannot flash them the conventional way via windows.
  2. Hengu
    Hengu Newbie
    Anyone that has done this, could you please provide some links to where you can buy said parts?
  3. FirebirdTA01
    FirebirdTA01 Newbie
    eBay, that's where I bought mine from.... speaking of:
    Hi, I purchased an MSI gtx 1070mxm for attempted use on my m17x r4. When I plug the card in and attempt to boot, it's not recognized in bios. It says "not detected." I'm running unlocked a11 bios. Can anybody advise?
  4. Rengsey R. H. Jr.
    Take the card out. reboot into bios and change the graphic setting to SG mode , shut down and re-install the card and reboot.
  5. Handale30
    Handale30 Notebook Guru
    Hello guys and good day!! I'm interested in upgrading my Alienware M17x R4 laptop with a GTX1060 OR GTX1070
    specs:
    Alienware M17x R4
    Intel i7 3820QM
    GTX 680M 2GB
    3D 120hz FHD screen
    Options:
    GTX 1060
    GTX1070 MSI
    GTX 1070 EUROCOM 115W
    Questions:
    1) if I had the gtx680m 100w card can I use its heat sink for the gtx1060?
    2) other than the cutting of the chasis for the gtx1070 does it end up working fine or always throttles and heats up because of the 150w?
    3) the Eurocom gtx1070 115w does it work with the Alienware m17x r4 with the 3d display? I read somewhere the updated a vbios and its worked on a 3d 17 Ranger. That would be the perfect card because it fits and has a lower tdp
    Thanks a bunch in advance!! :)
  6. FirebirdTA01
    FirebirdTA01 Newbie
    I've had the bios in SG mode the entire time. My old card is detected no matter what I do, the new one isn't detected no matter what I do
  7. Rengsey R. H. Jr.
    That's really odd how it is not detecting it. Have your tried to flash a different bios via an external flasher ? See if other bios work.
  8. AlienHack
    AlienHack Notebook Evangelist
    guys i also have an m17x R4 with the same specs as Hendale30.
    i can find the clevo (is this the same as eurocom?) card very cheap.
    do you think it will fit and work?
    thanks
  9. Handale30
    Unfortunately that wont fit the m17x r4
  10. AlienHack
    so the only solution is the MSI one ? (with black PCB)
    why wont it fit? just curious
