MSI GT80S GTX 980 work in Clevo
Discussion in 'Sager and Clevo' started by Damin, Aug 1, 2018.
  1. Danishblunt
    Danishblunt Guest
  2. Damin
    Damin Notebook Consultant
    There was a bit of plastic that I cut not a big issue was very easy but as soon as I have the GPU showing as a 980 and the benchmarks done properly then I will do a detailed step by step with pictures :) 1 thing I know is it's about 2000 points better than a stock 980m on firestrike
  3. Damin
    Hello all Can any one help me with fixing the driver .inf .. im having trouble :(
  4. andrewff2
    andrewff2 Notebook Evangelist
    Did you try the modified driver from @j95 ?? I just go HERE and download the driver :D
    Damin likes this.
  5. Danishblunt
    Danishblunt Guest
    yeah no problem. I can help you out.
    Throw me a private message with discord/steam add.
    Damin likes this.
  6. Damin
    Hello Danish I sent you a PM was that the correct information
  7. Damin
    after much messing around its working and coming up as 980 in device-manager .. now im going to try put the backplate back on the card and use Thermal Grizzly Conductonaut Liquid Metal Untitled.jpg
