MSI GT75 TITAN 8RG-094 Review by Phoenix
Discussion in 'MSI Reviews & Owners' Lounges' started by Phoenix, May 2, 2018.
  1. Falkentyne
    Falkentyne Notebook Virtuoso
    T
    Thank you for your feedback and testing. Appreciate it. Since you have a laptop which works as it was designed to work as, just leave that setting at default then.
    MSI users need to set IA AC DC to 1 to stop the horrid overvolting (mainly because MSI also combines this with internal, impossible to disable Loadline Calibration (LLC). The amount of LLC seems to be equal to a "medium" level used on a desktop board, but without a digital multimeter or knowing where the vcore read points are, impossible to know for sure. No schematics are available....
    Papusan, Mr. Fox and yrekabakery like this.
  2. Falkentyne
    I do not understand you.
    can you GET into the Bios after the automatic boot loops finish?
    Or is the laptop crashing and rebooting before you load windows?
    Tell me--CAN you enter the Bios?
    Make this clear, please.
    if you CAN enter the Bios, then set it to UEFI. That's how these laptops are supposed to be used at, NOT LEGACY. Period.
    If you can NOT enter the Bios, RMA it.
  3. yrekabakery
    yrekabakery Notebook Deity
    And thank you for the settings advice, learned a lot from it. It's interesting how the same BIOS settings have different results on Clevo vs. MSI. On my Clevo, IA AC/DC Loadline 1 definitely hurts more than it helps. When I change them back to 0, I'm Prime stable at lower VID, with no more 'EDP Other" throttling when running non-AVX Small FFTs:
    I also figured out my TS Bench errors. The newest version of TS Bench is more power hungry and runs at lower VID, plus my NVRAM was corrupted after tweaking BIOS settings too many times. After a CMOS reset and bumping up from 1.175V to 1.2V, no more errors. :vbthumbsup:
    PS: Sorry for the OT, MSI owners. I thought my BIOS settings exploration might be applicable to you guys/gals as well, but turns out our laptops are quite different. :vbbiggrin:
    JeanLegi, Papusan and Mr. Fox like this.
  4. Falkentyne
    Nah MSI owners need to see this.
    Clevo makes a non cancer laptop with Prema Bios, which performs exactly like a "Mini ITX" desktop would perform.
    MSI makes cancer. MSI owners NEED to see this.
    raz8020, JeanLegi, Mr. Fox and 2 others like this.
  5. ThePerfectStorm
    ThePerfectStorm Notebook Deity
    If only the P870TM1 had a mechanical keyboard and 120hz 3ms screen, it would be an automatic choice for a lot more people. Hoping Clevo somehow sees this post.
    Sent from my iPad using Tapatalk
    JeanLegi and Falkentyne like this.
  6. hanswalter
    hanswalter Notebook Enthusiast
    Hello sorry for the Confusion.
    1. Notebook is powered off
    2. Press Power Button
    3. Fan are spinning
    4. Power Button glow red
    5. no MSI Logo , Screen is black
    6. Power Button goes black
    7. then it stuck in the loop with Power Button glow red -> goes black and so on
  7. Falkentyne
    Did you or did you not hold down the power button DOWN PRESSED DOWN for 60 seconds?
    If you did, RMA the laptop. Either it's broken or the RAM is broken.
  8. flake90
    flake90 Notebook Enthusiast
    What are exatly ram modules in stock notebook with 16gb ram? I want to plug in another 16gb but i dont know what i need to buy.
    Donald@HIDevolution likes this.
  9. Zoltan@HIDevolution
    Zoltan@HIDevolution Company Representative
    You should install HWinfo64 and it will show you the exact part number of the RAM installed in your laptop. https://www.hwinfo.com/files/hwi_584.exe
  10. JeanLegi
    JeanLegi Notebook Consultant
    or cpu-z both are good for needed information for memory etc.
