MSI GT73VR 7RF Titan Pro-425 Review By Phoenix
Discussion in 'MSI Reviews & Owners' Lounges' started by Phoenix, Feb 9, 2017.
  1. Phoenix
    Phoenix Super Tweaker
    Specifications:
    CPU: Intel Kaby Lake i7-7820HK @ 4.2 GHz
    Memory: Kingston MSI24D4S7D8MB-16 2400 MHz.(17-17-17-39) 64GB DDR4 RAM
    GPU: GeForce GTX 1080 8GB GDDR5
    Thermal Paste: IC Diamond on the CPU + GPU using the X Cross Method
    Screen: Chi Mei N173HHE-G32 17.3" FHD 120 Hz/5ms screen (G-SYNC)
    Wireless: Intel Dual Band Wireless-AC 8265
    Storage: 2x Samsung 960 PRO 2TB [Super RAID 4] + 850 EVO 1TB m.2 + 850 EVO 4TB SSDs
    Mouse: Logitech G900 Chaos Spectrum Wireless Gaming Mouse
    Power: 330W AC Power Adapter
    Operating System: Windows 10 Pro 64-Bit
    Price as Configured: $8000 USD
    Where to buy: HIDevolution
  2. Phoenix
    Video Review:
    MSI GT73VR Titan Pro Screen Bezel Disassembly
    4.2 GHz Overclocking settings for the i7-7820HK:
  3. Phoenix
    Benchmarks:
    Note: The benchmarks were run with HWiNFO in the background for monitoring the temps. The scores would be higher by around 10% if I didn't have HWiNFO in the background
    PassMark Performance Test 8
    3DMark11 - GTX 1080 (378.66) CPU 4.2 GHz-GPU OC 150-350 [W10]
    CPU @ 4.2 GHz / Cache Ratio @ 4.0 GHz
    GPU Core @ 200 MHz / Memory @ 350 MHz
    Fire Strike - GTX 1080 (378.72) CPU 4.2 GHz-GPU OC 200-350 [W10]
    Time Spy - GTX 1080 (378.66) CPU 4.2 GHz-GPU OC 150-350 [W10]
    CINEBENCH-7820K @ 4.2 GHz-1080 GTX @ 150-350 MHz:
    wPRIME:
    AS SSD Benchmark:
    CrystalDiskMark:
    ATTO Disk Benchmark:
    Atma, infex, neohopper and 3 others like this.
  4. Phoenix
    Internals of the laptop:
    Love the m.2 drives heatsink on this laptop, covers all the three m.2 SSDs to ensure that they don't overheat:
    MBN, Huniken, Atma and 3 others like this.
  5. Papusan
    Papusan JOKEBOOKS = That sucks!! STAHP! Dont buy FILTH...
    Phoenix likes this.
  6. Phoenix
    Just ran a 3DMark11 test with the CPU overclocked to 4.2 GHz on all cores. GPU at stock speeds. GSYNC = ON. FAST SYNC = ON. Texture Quality = HIGH. Power Management = Adaptive
    I can obviously get a higher score by setting the GPU to High Performance and the texture filtering to High Performance but I wanted to show you how performance would be in a normal users' usage scenarios, that is, with adaptive power management to not make the GPU always work on the highest clock speeds which wouldn't make sense if you're watching a movie or browsing the web, and I also kept GSYNC enabled but with FAST SYNC enabled for the Vertical Sync. that way, the max FPS isn't limited to the screen refresh rate but you still won't get any screen tearing.
    Atma, hmscott and infex like this.
  7. Phoenix
    BTW, in the above tests, the fans were on auto not max speed. I could barely hear them spinning. This laptop's cooling is awesome and it's very quiete
    Huniken and Atma like this.
  8. Atma
    Atma Notebook Deity
    What size stripe did you decide to use for your raid?
  9. Phoenix
    I initially wanted 64K but then a user here posted an image from the MSI manual where they suggest 128K for SSD m.2 RAID 0 so I went with that.
    hmscott and Atma like this.
  10. Phoenix
    4.2 GHz on all cores stable overclock:
