msi gt70 power button ribbon cable damaged
Discussion in 'MSI' started by mizozizo, Oct 11, 2018.
  1. mizozizo
    mizozizo Notebook Enthusiast
    My power button ribbon cable is damaged during me repasting/cleaning the laptop. now it won't connect to the power button in the upper panel and the laptop won't start unless i fiddle with the stripes on the cable with a screwdriver
    is there a way to fix it by stripping it's end like a normal cable? if not, where can i find one online?
    here are images
  2. Kevin@GenTechPC
    It needs to be replaced and the best point of contact is MSI. Be careful with it next time because it is fragile.
  3. mizozizo
    there's no contact point in my country not there's a service center for msi . can you pint out somewhere online i can buy that cable from please ?
  4. t456
    Any generic flat ribbon cable will do. They're the same cables MSI's ODM bought when assembling the device.
    You need to measure pin pitch, length, count the pins and check whether it's 'forward' (same-side exposed) or 'reversed' (flipped). Could also check the cable for a part nr., of course; that could point to the right type.
