MSI GT683R Upgrade - CPU, Fan and thermal Compound
Discussion in 'MSI' started by arquillos, Jan 2, 2019.
Tags:
  1. arquillos
    arquillos Newbie
    Hi, I have a MSI GT683R and I´d like to upgrade the CPU and the Fan if possible!
    Mi notebook details are:
    Code:
    CPU: Intel Core i7-2670QM
        Manufacturing Process:    0.032 micron
        Socket Type:    Socket G2
        Thermal Design Power:    45 Watt
    Motherboard: MSI MegaBook GT680/GT683/GT685/GX660/GX680 Series (MS-16F2)
    Motherboard Chipset: Intel Cougar Point HM67, Intel Sandy Bridge
    DMI BIOS Version: E16F2IMS V3.0S (Release Date: 08/17/2011)
    Upgrade    Socket: rPGA988B ("G2" or FCPGA988)
    Fan: T&T - B9733L12B-028 - 0,36A 12VDC - E330800182MC200B30058436
    1.- Replacing the CPU
    The goal is to replace the CPU without changing anything else, so starting from
    this web page:
    - http://www.cpu-world.com/Sockets/Socket G2 (rPGA988B).html
    I have to nice options:
    - i7-2860QM
    - i7-2920XM
    Here are the three processors characteristics:
    Technology (micron) Cores Threads Frequency (MHz) Turbo freq. (MHz) L2 cache (KB) L3 cache (KB) TDP (Watt)
    i7-2670QM 0.032 4 8 2200 3100 1024 6144 45
    i7-2860QM 0.032 4 8 2500 3600 1024 8192 45
    i7-2920XM 0.032 4 8 2500 3500 1024 8192 55
    Based on benchmarks (https://www.cpubenchmark.net/), the 2920XM and the 2860QM
    have very similar results...so I think that the 2860QM should be the selected one
    as the 2920XM uses 10 more Watts...it should generate more heat too, isn´t it?
    And so, the question is:
    - Replacing the i7-2670QM with a i7-2860QM should work without changing anything else?
    Should the BIOS work with this CPU (Frequency and Turbo freq. are higher)?
    2.- Thermal Compound
    I´m going to "update" the thermal compound from my CPU and GPU.
    I´ve found that the Thermal Compound HY-880 is a nice replacement:
    http://forums.pureoverclock.com/reviews-articles/26113-hy810-hy880-compound-review.html
    - Have any one tried it? Is it worth it?
    3.- CPU and GPU Fan
    My notebook fan is working nicely but I´d like to replace it with a new one that
    generates more airflow.
    The actual one is this:
    And I´m able to find a similar replacement but not a "better" one.
    - Anyone knows of a better fan that could improve to cold down the system?
    Thank you in advance!!!!;):);)
  2. Danishblunt
    Danishblunt Guest
    2920XM since it can overclock
    ICDiamond as thermal compound
    There is a modded fan on ebay, some russian guy is selling those.
  3. arquillos
    arquillos Newbie
    Thanks Danishblunt!
    I´ve found the ICDiamond compound. I will try it!
    I´ve been searching in ebay for this modded fan with no luck...any clue? any name? any link?
  4. Danishblunt
    Danishblunt Guest
  5. arquillos
    arquillos Newbie
    Thanks Danishblunt!!
    I´ll try it!
  6. arquillos
    arquillos Newbie
  7. Danishblunt
    Danishblunt Guest
  8. johnbb
    johnbb Notebook Consultant
  9. arquillos
    arquillos Newbie
    Thank you Danishblunt and Johnbb for your help and advice!
    Ok, I´ll look for the 970m or 980m.
    Another question: a GPU like the 970m or 980m would require around 100Watts...around 25Watts more than the actual 560m card needs. With the stock 150W power supply unit I´m afraid it won´t be enough, isn´t it?
    And about brands...shoud I stick with Clevo or Alienware...no DELL. Why no DELL?
  10. arquillos
    arquillos Newbie
    Finally I did it.
    New i7-2860QM since I did not pretend to overclock the system and also the i7-2920XM cosumes 10W more and so it would need a new PSU unit...maybe.
    CPU + Thermal Paste + new Fan installed without any problem, replacing the pieces was very easy.
    PassMark benchmark gives the new system a global 2.973 while the original was 2.274 (+30% difference)
    The "new" system feels better and responsiveness and games like FSX SE that depends on CPU show an increment of 10fps.
    Thank you everyone for the help! I´ll keep looking for a GPU replacement.
