msi gs70 optimus problem
Discussion in 'Gaming (Software and Graphics Cards)' started by nabilghali, May 6, 2018.
  1. nabilghali
    nabilghali Newbie
    i was playing a game on my laptop then i connected it to an external screen via hdmi after i closed the game the power button still orange meaning that the laptop (msi gs70 2od) still using nvidia graphic card
    restarted the device and the power button stiil orange
    disabled the geforce 765 m through device manager and it is still on
    reinstalled the nvidia driver and no fix
    any thoughts please and sorry for my english
  2. don_svetlio
    Are you sure that's what the light means? Orange light usually means battery charging.
  3. nabilghali
    nabilghali Newbie
    thanks for quick replying .no the power lid is blue when it uses intel card and it is orange when nvidia card is inuse also the laptop is pretty hot from right side meaning it uses nvidia card
  4. Danishblunt
    Danishblunt Guest
    You cannot turn the Geforce graphicscard off, All the external ports are connected via the 765M, if you would turn it off then you would have no screen. That's also the reason why MSI notebooks with optimus are VR ready.
  5. nabilghali
    nabilghali Newbie
    i had that laptop for 3 years now and it was fine the 765m in use only while gaming (orange power light) and it is blue when no games are on but now it is always orange just after i turn on the laptop this consumes power and make the device hot over time
    all this happened after connecting hdmi to an external screen don't know why
  6. Danishblunt
    Danishblunt Guest
    Welp, if you would stop ignring me then you would know why, I guess we will never know. ¯\_(ツ)_/¯
  7. nabilghali
    nabilghali Newbie
    sorry i don't ignore you i just want to know why this particularly happened now why it doesn't switch between the two graphic cards as it always had
  8. don_svetlio
    If all the ports are routed through the dGPU then unplugging the HDMI cable will solve the issue
  9. nabilghali
    nabilghali Newbie
    it didn't solve it .i thought that there is a program that uses nvidia card but there was no programs using it
  10. Danishblunt
    Danishblunt Guest
    You're totally igorning me. Because I answered your question in my first post.
    You can deactivcate the GTX 765M in your device manager, that way all external outputs should not give a screen and the card should not be working.
