MSI GS63VR Display Panel
Discussion in 'MSI' started by RagingOcelot, Aug 24, 2016.
  1. Tanner@XoticPC
    Tanner@XoticPC Company Representative
    That's the one I was thinking about. It's not that they are bad screens overall, just there's a lot of variance in them.
  2. guyinlaca
    guyinlaca Notebook Enthusiast
    Tested another 252 model at Best Buy. It also had the extremely poor Chi Mei screen. The viewing angles and contrast are far worse than the 001 they also had on display. Just another warning, if you're going to be using this without an external monitor, do NOT get the 252 if you're at all worried about screen quality.
  3. Tanner@XoticPC
    There's a reason they cost less than equivalent models elsewhere.
  4. eurodj101
    eurodj101 Notebook Geek
    One has two choices...live with it if u buy it or spend a bit more and get a better model...In all honesty i dont recommend the average joe to just do wha ti did and swap panels.
  5. Kevin@GenTechPC
    Save the hassle on swapping and go with a better model that uses a better panel. It may be cheaper this way. :)
    eurodj101 likes this.
  6. ResidentJack
    ResidentJack Newbie
    What screen did you end up getting? I also need high srgb and adobe rgb for work and want a pro 4k scrren.
  7. Stanley08
    Stanley08 Notebook Consultant
    Hello Guys! I bought an MSI GP62MVR laptop. Fantastic performance. Especially after swapping out the HDD for an SSD. But the thing is, it came with this LG Panel (LP156WF6-SPK1) which isn't really a great panel per-se. Display is washed out, though some calibration icc file and cranking up saturation in Intel Graphics control panel helps, still doesn't take all the problems away.
    I had the Dell 7559 laptop before. Upgrading was EASY! Screen, and even only one screw to get the everything under the hood. A dream really! (16 screws under the MSI LOL!).
    Anyways, i also bought the AUO B156HAN01.2 which is a fantastic screen but i'm looking to replace it now and i saw where Tanner@XoticPC wrote about breaking the bezel or so. I didn't find a bezel named for my laptop. But can anyone confirm to me that this is the same Bezel? Same one for MSI GE62
    http://www.ebay.com/itm//162451975527
    It sure does look similar. Thinking of buying it before i attempt to replace my display
  8. Matt123pj
    Matt123pj Newbie
    Hey, I read through all of these, but I can't seem to get an answer for my question. I'm looking to purchase a gs63vr 001, i csnt afford the 4k option right now I am now reading the 001 has a bad panel. Can I change that panel for a 4k panel? Would the 4 lane edp connector work for the 001 (30 pin 2 lane) model? Which one of these panels would work?
    http://www.panelook.com/LQ156D1JW31_SHARP_15.6_LCM_overview_26820.html
    http://www.panelook.com/LP156UD1-SPB1_LG Display_15.6_LCM_overview_26868.html
    Thanks alot!
  9. Kevin@GenTechPC
    eDP is the type of connector used but the panel used 2 lanes instead of 4 so let's wait for others who had done this before to give you an answer.
  10. Matt123pj
    Matt123pj Newbie
    Ok, I'm thinking I would just buy 001 model and just swap out for the better 4k display. The price isn't bad for it. I just need to make sure that it will work. I don't want to be stuck with a bad panel.
    Kevin@GenTechPC likes this.
