MSI GS60 Ghost/ Ghost Pro Thread
Discussion in 'MSI' started by GreaseMonkey90, Jan 14, 2014.
  1. Spanker15
    Spanker15 Notebook Guru
    So my GS60 has this problem where when I press a specific spot on the laptop its makes kinda of a cracking sound. It's not that big of a deal but is a bit annoying since a lot of times I just pick up the laptop with one hand from that side to put it in the bag and makes that noise.. Here's a quick vid of the sound it makes : https://vid.me/rqlL
    Do you guys know what might be happening and would it be a easy fix?
  2. IBP-Andy
    IBP-Andy Company Representative
    It could be that the plastic clip on the inside broke, and the two sides of the cover are clipping each other to make that sound. can you see any movement of the cover when you apply pressure?
  3. Spanker15
    The movement seems to be the same on the side that makes this sound and the other side of the laptop which is ok. Looking from the outside it doesn't seem to exist a visual difference when applying pressure on the two different sides.
  4. WhatsThePoint
    WhatsThePoint Notebook Virtuoso
    Are all the screws tight that hold the bottom plate including the keyboard screw and the bottom plate securely snapped to the case.
    Is the bezel around the screen snapped together all the way around
  5. Derek712
    Derek712 Notebook Virtuoso
    I have this problem because I broke a clip on my bezel when putting it back together. It's only on the right side of my computer and only when I grab it in the middle.
  6. Spanker15
    All the screws seem to be ok its probably the same problem as yours..
    So there's no way to fix it then ? I doesn't bother me enough to RMA it but would be nice to fix it
  7. Derek712
  8. Kevin@GenTechPC
    Hopefully it is a major leap in performance, but price will definitely drop for existing platform.
    WhatsThePoint likes this.
  9. Derek712
    I installed the 2133Mhz ram and ran some benchmarks. I'm still working on my review, but to make a long story short, don't waste your money. I ran numerous benchmarks and games and could not tell the difference at all. It did run at 2133Mhz though but keep in mind I installed it on a Broadwell machine and I still am not convinced it would work on Haswell.
    Kevin@GenTechPC likes this.
  10. thedj
    thedj Notebook Guru
    My current GS60 has everything in terms of performance but I don't like the matte screen, I would like to to get it with a glossy screen and my RMA has been accepted. I was going to get the 4k version which is the only one that comes with a glossy screen, but I only just found out that it has a 48hz refresh rate (even though my resolution will be set to 1080p only). Has anyone got the 4k version and what do you think about the refresh rate? Is the 12hz difference noticeable?
Similar Threads - GS60 Ghost Ghost
  1. clayton006
    17
    1,179
