MSI GE75 worse temps after repaste
Discussion in 'MSI' started by berkkocaturk, Apr 2, 2021.
  1. berkkocaturk
    berkkocaturk Notebook Consultant
  2. Papusan
    etern4l likes this.
  3. berkkocaturk
    Only on tech people say this if i but a car which has internal combustion it will last more than a laptop it is only because planned obsolence and cheaping out laptops can be made very well if something happens it will directly go to warranty gpu and cpu should handle all type of load
  4. Papusan
    I'm sure the engineers know the hardware's limits. If the GPU can handle all type of load... Then why change the warranty?
    You may dislike MSI even more after reading this. MSI reduces warranty times for twelve Geforce models....It now appears that MSI...
  5. Sylvester John Apo
    Sylvester John Apo Newbie
    Dude, you gotta use Hydronaut. It is recommended for laptops with high temps over 80C. It reduces the chance of pumping out. I have used a lot of pastes and dang, this thing was the best! You just gotta spread it evenly and just put a little bit at the center to be sure. It’s the best!
  6. cuneyt1984
    cuneyt1984 Notebook Consultant
    Friends, The Only Solution:
    "Cooler Master" Mastergel Maker Nano.
    It will be great when you apply it on Vrm, Cpu and Gpu.
    "Note: There is no need for Liquid Metal Because there will be no performance increase in Notebooks because the power of the Adapter is limited."
  7. berkkocaturk
    I have already repaste with kryonaut . The cpu and gpu is still hot but I am thinking the cooling is just very inadequate
  8. cuneyt1984
    Brother Berk, I think some sellers are selling counterfeit products. I bought an Arctic Mx-4 before.It was fake. The inside of such products can be changed. Because it is very easy to pack.
    The Cooler Master Mastergel Maker Nano box is original fabricated.Take this if you live in Turkey. I used it very well.
    https://urun.n11.com/sogutucu-ve-fa...nano-elmas-partikullu-termal-macun-P206370221
  9. cuneyt1984
    Also apply fabricated thermal pads correctly.
  10. NeXt3R
    NeXt3R Notebook Evangelist
    oem setting ,.,not OC ??
    some apps destroy oem setting "TS" or DC contains custom setup for CPU / SYSTEM
    undervolt / CLOCK lock - around 90C max
    CPU/GPU
    fan curve - last two points -150./.
