MSI GE73 Raider : Shutdown don't work and fans still working
Discussion in 'MSI' started by Julianinho, Apr 15, 2018.
  1. JeanLegi
    JeanLegi Notebook Evangelist
    the next step from my view of point would be a clean install of os and all drivers.
    Julianinho likes this.
  2. Julianinho
    Julianinho Notebook Geek
    Before reinstall i will wait if another member have other solution ;) and maybe the new update of windows can solved this.
    I can try to uninstall completely the gpu nvidia and use the laptop only with the intel hd graphic for few hours and see if i can shutdown.
    Thanks for your help :)
    JeanLegi likes this.
  3. asm1
    asm1 Notebook Consultant
    Might be entirely irrelevant but it looks like you haven't installed the management engine update which fixes the Spectre/Meltdown CPU bug. My patched version shows 11.8.50.3425
    Might be a tholught to do that update.
  4. Kevin@GenTechPC
    The ME does not contain fixes for speculative execution, it's the microcode used in the BIOS.
    asm1 likes this.
  5. Julianinho
    @asm1
    Thanks for info, i have update with the file me118h.bat, now i have the same version to you.
    I will test if my ge73 can shutdown or not.
    I have to use more hours because the laptop shutdown ok when i use it for few minutes but it didn't shutdown when i use it for 1 hour or more.
  6. asm1
    No worries. Its not related to your problem as @Kevin@GenTechPC says but I thought I'd mention it.
  7. Julianinho
    Ah ok, so you don't have any idea for my problem ?
  8. Kevin@GenTechPC
    It's possibly a GPU issue so if BIOS/EC update doesn't resolve the issue then send it back to MSI for warranty service.
  9. Julianinho
    I don't know if is the patch v11.8.50.3425 but when i shutdown my ge73 it's works, i have try 2 days and shutdown 10 times my laptop and it work, but the restart don't work.
    Thanks for your help, i can shutdown now ;)
    Kevin@GenTechPC, JeanLegi and asm1 like this.
  10. asm1
    Glad you got it partly solved. :)
    Julianinho and Kevin@GenTechPC like this.
