MSI GE62VR 7RF disturbing sound
Discussion in 'MSI' started by katates, Mar 29, 2017.
  1. katates
    katates Notebook Enthusiast
    My brand new laptop has disturbing sound coming from between under the touchpad and left speaker. (Probably from 2.5" hdd)
    When the room has no sound I can hear it very well in High Performance Mode, the other power options are acceptible but if you listen you can hear it anyways.
    Its like the sound at 20secs
    Its almost a week old. Is this a common problem or should i sent it to service.
  2. don_svetlio
    Not sure if it helps, but maybe this has the sound in question in better quality? Datacent's database has been useful in my experience with WD - it's at least worth a try.
    Though an RMA might not be a terrible idea.
  3. SkidrowSKT
    SkidrowSKT Notebook Deity
    Here's a better solution:
    Keep this HDD and make it external, and replace it with a 2.5" SATA SSD. SSDs are ultra quiet!
    Sent from my SM-N900 using Tapatalk
  4. katates
    I couldn't find it there but its like the when you bring something electrical near to speakers you hear sounds its like that but less disturbing.
    That is not a solution.
  5. Kevin@GenTechPC
    Request for RMA for hard drive only, let them know that you can't be without your PC.
    Do ask politely since this request isn't a standard procedure.
    don_svetlio likes this.
Similar Threads - GE62VR disturbing sound
  1. Brenden Weaver
    319
