** MSI GE62 Apache (and Pro) Owner's Lounge**
Discussion in 'MSI Reviews & Owners' Lounges' started by anethema, Feb 23, 2015.
  1. Jaxione
    Jaxione Notebook Consultant
    Deleted
  2. asm1
    asm1 Notebook Consultant
    Glad you got it sorted
    FYI: https://www.msi.com/Laptop/support/GE62VR-7RF-Apache-Pro.html#down-bios - is the support page for your laptop, it had recent bios updates and EC Firmware, as well as a patch for the intel management engine fix a few weeks ago. I mention it because MSI can release fan profile updates as well.
    Kevin@GenTechPC likes this.
  3. Jaxione
    Thanks, what does Intel management engine do?
  4. asm1
  5. Kevin@GenTechPC
    It controls the behavior of your CPU/Chipset, etc. Basically it's like reflex part of cerebellum.
    Donald@HIDevolution and asm1 like this.
  6. Jaxione
    Thanks. If I can find a new lid, how do I change it? How much do I have to dissasemble?
  7. Kevin@GenTechPC
    You may have to disassemble the whole system, including the base due to wiring.
    Donald@HIDevolution likes this.
  8. andrheas
    andrheas Newbie
    Guys my screen is dead but i think its just the backlight because I can still see an image but no light. How muh will it cost to change it?
  9. Donald@HIDevolution
    Donald@HIDevolution Company Representative
    That will probably depend a lot on who you get to do it. Probably a question better asked of your vendor.
  10. Ksen
    Ksen Notebook Enthusiast
    Hi! My laptop is ge62vr 6gen. I have a problem with my temp it was running in sports mode and my temp reaches up to 93c in GPU but 60-65 in CPU for comfort mode my temp was 78c in GPU and 55-60 in CPU. Its already repasted and fan cleaned. I used unigine heaven benchmark.
    I want to ask if that is normal temp for both GPU and CPU? Or there is something wrong with the GPU temp? I also have vaccum cooling and cooling pad CPU and GPU was undervolted. I think my bios and EC isnt update but do you think it will help?
    Btw, my friend has the same unit and was clean and repasted like a month ago before me but his temp on sports mode was 75c tops.
    I appreciate the help! Thank you!
    EDIT: Could this also be a heatsink problem? Could the GPU heatsink failing thats why the temp was too much, can't even use sports mode.
