MSI 16L13 (Eurocom Tornado F5) Fan Modifications
Discussion in 'MSI' started by alaskajoel, Nov 12, 2017.
  1. FrozenLord
    FrozenLord Notebook Consultant
    Unfortunately, the clips have different designs (top is to be modded, bottom is stock) and can't be inserted without problems into the new 4 pin connector.
    They don't lock in place and given their fragile nature, I am going for the soldering option.
    Do you happen to have a page / documentation at hand that I can consult?
    So far, it seems there is no central database for fans and I am struggling to find even basic model specifications.
  2. t456
    ADDA provides yearly catalogs in pdf form. There's no 90x90x25mm blower fans on their current list though, so guess you'd need to find an older catalog.
    Could also sail by their numbering scheme; 'H' designates both fans as 'High' speed. That doesn't necessarily mean they're using the exact same maximum rpms. Some same-sized 'High' models are designed for 10k, while others can run 14,000 rpm. Mind that it can't hurt if it's a bit off, it's just that the fan profile could be a bit askew, ceiling before it ought to or resulting in lower- or higher-than-expected temperatures.
    ole!!! likes this.
  3. hfm
    hfm Notebook Prophet
    Why not just clip the wires themselves and solder the wires together.
  4. FrozenLord
    That is what I am going to do as soon as the new fan arrives :)
    I don't want to ruin a perfect replacement fan.
  5. yosv211
    yosv211 Notebook Consultant
    i miss my old F5 with the 7700k processor but I sure dont miss have to change the fans every 6 months. I've had to change the fans 3 times in 1.5 years.
  6. killerlac
    killerlac Newbie
    I would have a quick question.
    two gpu fan can be put in?
    Thx
  7. Kevin@GenTechPC
  8. FrozenLord
    Well, I have finally gotten around to use a defective fan's connector and soldered it to the AB08812HX26DF00.
    Checking it with a multimeter results in about 30 k Ohm for + against - and the other two pins (against + or -) have got a resistance of several M Ohms.
    So I would assume that there is no short and normal contact.
    However, (from my understanding) my laptop does not detect the RPM of the fan.
    It will spin up the fan just fine, then stop it a few seconds later to spin it even higher and will escalate that way.
    This seems to be the normal boot up / spin up procedure for the fan and I would assume that the EC does not get a signal, therefore supplying more power in an effort to make it spin.
    It seems that I am going to stick with my N395 for now :)
    Kevin@GenTechPC likes this.
  9. qwerty8224
    qwerty8224 Notebook Guru
    purchase fans pabd19735bm - n395 they reach speed 5000 / min
  10. Kevin@GenTechPC
    How is the noise level?
