MSI 16L13 (Eurocom Tornado F5) Fan Modifications
Discussion in 'MSI' started by alaskajoel, Nov 12, 2017.
  1. hfm
    hfm Notebook Prophet
    Why not just use m.2 heat sinks with some high quality pads like Fujipoly?
    https://www.newegg.com/Product/Product.aspx?Item=9SIAC8W6SF4125
    You could also probably run some supply lines from the actual USB ports to provide power. USB-C on the back would be a good candidate as it probably largely goes unused for most people.
    hmscott and alaskajoel like this.
  2. David Parushev
    David Parushev Notebook Enthusiast
    I already have heatsink with thermal pad ... problem is that this nvme controlled just run hot ... heat sink just get the heat but it needs air ... :/
    I am am just worried now if this hack can burn the motherboard :D if i have wired it wrong
    hmscott likes this.
  3. hfm
    Why not just run a USB cable from external to internal (small hole or maybe through the vent).. not much risk in that..
    hmscott likes this.
  4. David Parushev
    I tried the hacked adapter that i made. It works but not really effective to run fan on 3.3v without any space :D
    hmscott and hfm like this.
  5. hfm
    I'm surprised a heat sink with some decent pads wasn't enough to curb temps a little.
    hmscott likes this.
  6. hmscott
    It's a matter of airflow and air flow over surface area to dissipate heat. Adding a mass of metal to absorb heat only delays slightly the rise in average temperature, until the mass has attained balance with the SSD, then they both continue to rise in temperature.
    Some kind of heat transfer to the air, or a larger surface area - larger mass - needs to be set up to direct the heat away from the SSD.
    Even scattered air flow, distruption of the still air around the heatsink / SSD could help a little, it might be worth leaving on and buttoning it up to see if the temps are affected.
    Maybe a stiff piece of cardboard or other material can be used to funnel or focus the air away from the heatsink / SSD area, and direct it toward the nearest exhaust fan.
    FrozenLord and hfm like this.
  7. FrozenLord
    FrozenLord Notebook Consultant
    Your mod seems to be somewhat messy.
    And even though I understand why you are going to such lengths, I am not sure whether a simpler mod might be enough.
    Therefore: have you previously tried the foil mod:
    *** MSI 16L13 (Eurocom Tornado F5)/EVOC 16L-G-1080 15.6" Owner's Lounge ***
    While it will not offer the same cooling potential as using dedicated fans, it increases the surface area for heat transfer and (in my case) was sufficient to achieve tolerable temperatures on the NVME controller.
    hmscott likes this.
  8. David Parushev
    It's not a bad idea after all. I just wait for my step-up voltage module to come. I have some slim fans 8-10mm from hp laptop and they are perfect for the mod.
    After the first mod with the adda fans my PCH sensor goes to 80C+ and SSD goes up to 99C with thermal pad and radiator
    hmscott likes this.
  9. IllusiveMan
    IllusiveMan Notebook Consultant
  10. deathwingbg
    deathwingbg Notebook Guru
    WARNING: Just be extremely careful when you modify the wiring on the ADDA fans!!!
    I might have killed my EC while adjusting the wires on my ADDA fan, since EC is responsible for the fan control.
    As per this guide i cut the wires ... however i used the original AAVID plug* for the fan and at first i reversed the cable colors... The fan did not start.
    Then i realized that the colors should match if you use the original AAVID plug -- Black to black, Blue to Blue, Yellow to Yellow, Red to Red.
    You should only reverse the colors if you use the ADDA 4 pin plug which is reversed.
    Then i matched the colors and the fan started. However after another restart or two my laptop was completely dead (no light went on even after the PSU was plugged in). Same thing happened few months ago again when i was tinkering with the other ADDA fan, trying to figure out why it was not working. Back then the laptop started after the 50th try ...
    This time the laptop started after $120+ in repairs and 2 weeks + without laptop. I got my EC chip replaced twice, reprogrammed with the EC bios & another power responsible chip replaced.
    *The ADDA fans that i bought were 5 pin version instead of 4 that is why i had to use the 4 pin plugs of the original AAVID.
    Semmy, aaronne and Huniken like this.
