Mr. Fox's GeForce 345.20 Desktop Driver Mod for Alienware and Clevo Mobile GPUs
Discussion in 'Alienware' started by Mr. Fox, Feb 25, 2015.
  1. Mr. Fox
    Is it another clock-blocked turd driver or an unlocked one?
  2. octiceps
    octiceps Nimrod
    Clockblocked. It's the same as 347.52 with one additional hotfix: http://nvidia.custhelp.com/app/answers/detail/a_id/3636
    Mr. Fox likes this.
  3. Mr. Fox
    TBoneSan, reborn2003 and octiceps like this.
  4. TomJGX
    TomJGX I HATE BGA!
    Yeah, let's wait for the proper 349.xx driver... It better come soon :)
    reborn2003 likes this.
  5. reborn2003
    reborn2003 THE CHIEF!
    Woops I should have known it was too early and too good to be true. We'll have to wait it out a little bit longer.
    Just tested out this driver - Thanks Fox! Your right its performance is roughly the same as previous drivers.
    So far for me the 347.26 (Clockblocked) stock GPU clocks give me the best results in terms of stability and performance. So I hope that the new unblocked Nvidia drivers next month start from there and then having the ability to OC again we will be able to boost scores even higher. :vbthumbsup:
    Mr. Fox likes this.
  6. TBoneSan
    TBoneSan Laptop Fiend
    Just wanted to update this. It appears my issue was related to a crapped out BIOS (just a coincidence). Who would have guessed huh..actually Mr Fox kinda of did. Cheers Fella. Long story, Short, I fixed the problems and am now using these drivers without a hitch.
    Ohh and have that CUDA support shaved loads of time off a video render I did in Nero. Just what the doctor ordered as I need to use Nero over the next couple of months :vbthumbsup:
    UPDATE #3
    Nope, something ain't right with these and my system. It's the dame for the mobility drivers too. I get a black screen after a reboot sometimes and have to go into safe mode etc... then uninstall.
    @j95 and @Mr. Fox
    I want me some CUDA support for Nero. Is it difficult to add it in ? I'm back on 344.91, perhaps could learn how to become self sufficient.
    reborn2003 and Mr. Fox like this.
  7. j95
    j95 Notebook Deity
    Extract w/7-Zip both nvcuvenc64.dl & nvcuvenc32.dl -> rename "nvcuvenc64.dll & nvcuvenc32.dll" to "nvcuvenc.dll".
    nvcuvenc.dll (nvcuvenc64.dll/) -> copy to Default/System32.
    cmd (Admin)
    Code:
     %windir%\System32\regsvr32.exe %windir%\System32\nvcucenc.dll
    nvcuvenc.dll (nvcuvenc32.dll/) -> copy to SysWOW64
    cmd (Admin)
    Code:
    %windir%\SysWoW64\regsvr32.exe %windir%\SysWoW64\nvcuvenc.dll
    -> reboot.
    #3 http://forum.techinferno.com/nvidia/8290-[mod]-latest-nvidia-drivers-cuda-nvcuvenc-encoder-support.html#post114350
    B4n6k3, joluke, Mr. Fox and 2 others like this.
  8. TBoneSan
    Cheers brother this is awesome. Thanks for taking the time.
    There's a few things I'm not sure if I follow.
    What am I do do with the all the CMD promt addresses...?
    Code:
    and
    Code:
    What am I do do here? I am supposted to run the dll's? If so I am unable to run anything from CMD after I've dropped the files in SysWow64 and System32..?
    Also step 3 ?
    Code:
    [nv_commonBase_addreg]
    HKCR,"Wow6432Node\CLSID\{B63E31D0-87B5-477F-B224-4A35B6BECED6}",,%REG_SZ%,"NVIDIA CUDA Video Encoder"
    HKCR,"Wow6432Node\CLSID\{B63E31D0-87B5-477F-B224-4A35B6BECED6}\InProcServer32",,%REG_SZ%,"%10%\SysWow64\nvcuvenc.dll"
  9. Mr. Fox
    No, if I add the file that contains the newer profiles from clock-blocked crap drivers to this driver package it fails to install in Windows 7 and 8.1.1 so they will have to be manually installed or installed through GFE after installing the modded driver. Probably a version incompatibility issue.
    joluke and j95 like this.
  10. j95
    j95 Notebook Deity
    Just copy the renamed nvcuvenc DLLs and then run the corresponding commands to register each nvcuvenc.dll. There's no step 3, it's just a reference/INF.
    To clarify some things:
    1- v347.xx are the best drivers for 900s so far, probably one of the many reasons NV blocked OCing in the first place 'entiende', nvidia must remove the clock-block without messing up v347.xx TDP or it will be a throttling nightmare for AW/PEG users.
    2- HotFix drivers include many fixes, most of which NV won't admit + internal testing. e.g. v344.80 unrelated 'official' fixes and inferior performance compared to v344.75. NEVER THE SAME!...;)
    Yep, or the patched nvlddmkm.sys interfering.
    joluke and TBoneSan like this.
