Mr. Fox's GeForce 345.20 Desktop Driver Mod for Alienware and Clevo Mobile GPUs
Discussion in 'Alienware' started by Mr. Fox, Feb 25, 2015.
  1. 5150Joker
    5150Joker Tech|Inferno
    I haven't used Vegas in a while but basically when you go to "Render As" during the final steps, open up a custom template and under the video tab at the bottom is a drop down for encode. If you have CUDA enabled (usually installed by nvidia drivers), then you can simply choose "render using GPU only" and it should take care of it.
    Mr. Fox likes this.
  2. j95
    j95 Notebook Deity
    345.20 includes v344.80 hotfix too, but with v344.75 performance instead.
    reborn2003 and Mr. Fox like this.
  3. TBoneSan
    TBoneSan Laptop Fiend
    I̶'̶v̶e̶ ̶n̶o̶t̶i̶c̶e̶d̶ ̶a̶ ̶p̶r̶o̶b̶l̶e̶m̶ ̶a̶n̶d̶ ̶I̶'̶v̶e̶ ̶h̶a̶d̶ ̶i̶t̶ ̶r̶e̶p̶l̶i̶c̶a̶t̶e̶d̶ ̶2̶ ̶t̶i̶m̶e̶s̶ ̶s̶o̶ ̶f̶a̶r̶.̶ ̶F̶o̶r̶ ̶s̶o̶m̶e̶ ̶r̶e̶a̶s̶o̶n̶,̶ ̶m̶y̶ ̶m̶a̶c̶h̶i̶n̶e̶ ̶h̶a̶s̶ ̶b̶o̶o̶t̶e̶d̶ ̶w̶i̶t̶h̶ ̶a̶ ̶B̶l̶a̶c̶k̶ ̶s̶c̶r̶e̶e̶n̶ ̶2̶ ̶d̶a̶y̶s̶ ̶i̶n̶ ̶a̶ ̶r̶o̶w̶.̶ ̶ ̶E̶a̶c̶h̶ ̶t̶i̶m̶e̶ ̶h̶a̶d̶ ̶a̶ ̶n̶e̶w̶ ̶c̶l̶e̶a̶n̶ ̶i̶n̶s̶t̶a̶l̶l̶ ̶w̶i̶t̶h̶ ̶D̶D̶U̶ ̶w̶a̶s̶ ̶d̶o̶n̶e̶ ̶t̶h̶e̶ ̶n̶i̶g̶h̶t̶ ̶b̶e̶f̶o̶r̶e̶.̶
    I̶t̶'̶s̶ ̶v̶e̶r̶y̶ ̶s̶t̶r̶a̶n̶g̶e̶ ̶s̶i̶n̶c̶e̶ ̶I̶'̶v̶e̶ ̶r̶e̶s̶t̶a̶r̶t̶e̶d̶ ̶s̶i̶n̶c̶e̶ ̶i̶n̶s̶t̶a̶l̶l̶i̶n̶g̶ ̶t̶h̶e̶ ̶d̶r̶i̶v̶e̶r̶s̶ ̶e̶a̶c̶h̶ ̶t̶i̶m̶e̶,̶ ̶a̶n̶d̶ ̶b̶e̶n̶c̶h̶e̶d̶/̶g̶a̶m̶e̶d̶ ̶a̶ ̶b̶i̶t̶ ̶t̶o̶o̶,̶ ̶b̶u̶t̶ ̶a̶f̶t̶e̶r̶ ̶a̶ ̶s̶l̶e̶e̶p̶ ̶(̶y̶e̶s̶ ̶I̶ ̶h̶a̶t̶e̶ ̶n̶o̶t̶ ̶m̶a̶k̶i̶n̶g̶ ̶s̶e̶n̶s̶e̶ ̶t̶o̶o̶)̶ ̶o̶n̶ ̶a̶ ̶c̶o̶l̶d̶ ̶b̶o̶o̶t̶ ̶I̶ ̶g̶e̶t̶ ̶a̶ ̶b̶l̶a̶c̶k̶ ̶s̶c̶r̶e̶e̶n̶.̶
    I̶'̶m̶ ̶t̶r̶y̶i̶n̶g̶ ̶t̶o̶ ̶m̶o̶b̶i̶l̶i̶t̶y̶ ̶d̶r̶i̶v̶e̶r̶s̶ ̶o̶u̶t̶ ̶n̶o̶w̶.̶.̶ ̶w̶i̶l̶l̶ ̶s̶e̶e̶ ̶h̶o̶w̶ ̶t̶h̶a̶t̶ ̶g̶o̶e̶s̶.̶
    UPDATED BELOW
  4. woodzstack
    woodzstack Alezka Computers , Official Clevo reseller.
    we've been trixed ! o.0
  5. deadsmiley
    deadsmiley Notebook Deity
    I tried this out last night and it works perfectly fine with my finicky 880M. Thank you Mr. Fox!
    Mr. Fox likes this.
  6. Mr. Fox
    Did you get it fully sorted? What is BIOS settings?
  7. jack34
    jack34 Notebook Geek
    I also install and works perfectly on my AW17 with GTX880M.
    The performance is very good in my GPU.
  8. j95
    j95 Notebook Deity
    When using latest DDU v14.0 uncheck AMD Audio Bus (bug), setting doesn't stick so you will need to repeat this each time. Restore defaults PEG0,1.,2,3 & SA DMI configuration BIOS tweaks, those are for the 120Hz AWs (PEG0).
    @Mr. Fox included profiles?
    TBoneSan likes this.
  9. TBoneSan
    So that AMD setting is the cause of it?
  10. reborn2003
    reborn2003 THE CHIEF!
