mp light flashing red???
Discussion in 'Panasonic' started by ROAD HAMMMER, Dec 3, 2010.
  1. ROAD HAMMMER
    ROAD HAMMMER Notebook Consultant
    i have tryed to find some thing on the forms but no good i have a cf-29 and the mb bat fully charged my mp light started flashing red so i poped out the mb bat and it sitll flashing red so i poped in my cd drive and try to read a disk but not a disk in the drive and it is flashing red and the read act light at the same time it will not stop i have powered down and pull out the mane bat and psu
    repowerd up and same thing what is it trying to tell me as i have tryed to find some thing on it
    now as soon as i post this it has stoped and now showing green
  2. denrosten
    denrosten Notebook Evangelist
    I think it is telling you that the Mb battery is bad
  3. ROAD HAMMMER
    idk that bat works and holds up well if i unplug and plug it back it stops and turns green
  4. Almstprfct1
    Almstprfct1 Notebook Consultant
    I had a 28 that would be green and then flash red...it turned out to be the cord that plugged into the power supply...
  5. mnementh
    mnementh Crusty Ol' TinkerDwagon
    Try charging only the main or MB battery one at a time; it may not be switching the main/MB battery properly if both are very discharged. This can cause a voltage drop that will trick the protection circuit.
    mnem
    Charged.
  6. adamwest436
    adamwest436 Notebook Evangelist
    On the 72 if I tried dual dead bat charge it never flashed the MP light but the screen would flicker on and off under heavy cpu usage. Before then I was using the battery charger and the yellow tip from the 29 or 51 to charge the media bay battery separate. The media bay would go 100% and the main would be 98-99%
