mouse pad running backwards
Discussion in 'Panasonic' started by mustangii, Jan 25, 2021.
  1. mustangii
    mustangii Notebook Guru
    CF-31jagcx1m, replaced the mouse pad with one I got on ebay. now it runs backwards. Drag right curser goes left and vice versa. drag down and it goes up and vice versa. is there a fix?
    edm
  2. steve.steve
    steve.steve Company Representative
    You bought a mouse pad for an mk1. You need a mouse pad for an mk2 and later.
    toughasnails and Shawn like this.
  3. mustangii
  4. steve.steve
    It would be nice if someone would write a custom driver. I have hundreds of those mouse pads
  5. Shawn
    There is a small application that will flip and reverse the touchpad. I will not be able to remember the name of it.
    I made this same mistake a few years back.
    I even fabricated an adapter to flip the output wires from the trackpad. Only has four connections. That worked great for me.
  6. Shawn
    Old posts on the subject...
    CF 31 mk2 --TOUCHPAD--N2EAYYY00022
    CF 31 mk1 --TOUCHPAD--N2EABEC00006
    CF 31 mk3 -- TOUCH PAD--N2EAYYY00022
    For all that you have problems with inverted axis (as moving from original touchpad model N2EAYYY00022 to older touchpad model N2EABEC00006) you can resolve this problem with Sakasa Mouse. This small utility that works instantly after is run (Work on XP, 7 and also 10). It can be used as startup programs and you will have instantly mouse working perfectly after Windows start.
    N2EABEC00006 has the advantage is more easily to find and also is much more cheaper.
    I dont know about Linux but i'm sure there is an utility for penguin lovers too. :)
    You can get it from HERE http://hp.vector.co.jp/authors/VA026826/sakasa103.zip
    For all sw that RESOLVE this problem look at this page: https://www.pcgamingwiki.com/wiki/Glossary:Invert_Y-axis
    So far it appears the CF19mk6 and later and CF31mk2 and later..
    Panasonic Integrates Interlink’s ‘VersaPad™’ Touchpad with the Toughbook® 31 Laptop
    August 01, 2011 11:00 AM Eastern Daylight Time
    Interlink’s VersaPad is a resistive touchpad that uses a unique pressure sensing technology, enabling exceptionally light touch and smooth tracking. Unaffected by moisture and other contaminants, the VersaPad is operable with any glove or passive stylus, and may be environmentally sealed to NEMA 4X / IP65 standards. This compelling combination makes the VersaPad ideally suited to the harsh environments in which the Panasonic Toughbook excels. The VersaPad is supported by a mouse driver which provides users with an advanced feature set and multi-language support.
    Interlink's VersaPad touchpad integrated into Toughbook 19 Posted on November 28, 2012
    Interlink Electronics, Inc. has announced that Panasonic has integrated Interlink's VersaPad® touchpad technology into a second Panasonic Toughbook® mobile computer specifically designed for civilian and military use in the harshest outdoor environments - from oil field to battlefield. Interlink's VersaPad® is now built into the latest Panasonic Toughbook® 19 convertible tablet PC, a fully-rugged mobile computer which is MIL-STD-810G and IP65 certified by an independent third party test lab to survive extreme conditions, such as drops up to six feet, rain, pressure, dust and extraordinary swings in temperature. Last year, Interlink announced that Panasonic had chosen VersaPad® for its upgraded Panasonic Toughbook® 31 rugged laptop. Both Toughbook® computers are designed for use in mission-critical situations by first responders, military personnel and field workers in such industries as telecommunications, utilities and energy.
    Read more at: http://www.printedelectronicsworld.com/ ... ughbook-19
    "The touchpad on Toughbook computers is a critical user interface, and we chose to upgrade our popular Toughbook 19 PCs with the Interlink VersaPad, following their success in our Toughbook 31 laptops, to help us surpass our customers' high expectations for user experience, reliability and quality."
    [/B]
