Morro - first thoughts
Discussion in 'Security and Anti-Virus Software' started by ATC, Jun 20, 2009.
  1. rflcptr
    rflcptr Notebook Consultant
    You can set exceptions.
  2. coolguy
    coolguy Notebook Prophet
    MSE doesn't update it's malware definitions everyday automatically even if Windows Update is set to install updates everyday.
  3. ATC
    ATC Notebook Deity
    I tried that. See image below (it made no difference):
  4. rflcptr
    Try excluding the location as well.
  5. ATC
    ATC Notebook Deity
    +rep to you. That did the trick! Thanks :)
  6. rflcptr
    Awesome. Thought the problem might have been with dlls, so that was my first guess.
  7. truebullfan
    truebullfan Notebook Consultant
    anyone know when the beta will be open to the public again? Or the RC?
  8. Jayayess1190
    Jayayess1190 Waiting on Intel Cannonlake
    Download
  9. RangerXML
    RangerXML Army of None [TRH]
    I like it, and it does not require Automatic Updates. I was using it with where Windows let me know if updates were available and could update it manually from within MSE.
  10. Ariakas
    Ariakas Notebook Enthusiast
    I just switched over to MSE, got it from Softpedia as I am in a location not available for download. I like it, light on resources and simple to use. Made the switch due to Avira Antivir not working on Windows 7 RTM. Avira was fine for Windows 7 RC.
