Modding My Cooler Master NotePal U3 PLUS
Discussion in 'Accessories' started by XiCynx, Oct 7, 2017.
  1. d00minat0r14
    d00minat0r14 Notebook Enthusiast
    1. https://www.forit.ro/ventilatoare-r...ML120+Magnetic+Levitation+120mm+PWM+White+LED
    i found it with pwm....same as that one it's ok no?
    2. also the fan controler has 3 pin connection...it's ok or i need something else with 4 pin?
    https://www.emag.ro/fan-controller-...lbastru-fc4thp/pd/DGRZ14BBM/?ref=fav_pd-title
    3.do i need PC Computer Fans, Independent Turn Knob Control? if yes can u update your link from your post is not working anymore
    4[​IMG]
    https://imgur.com/a/poH7Dxn
    what do u think could work like this ? not to cut anything from cooler master u3...in need 2 fans to be like this pic to reach my laptop cpu and gpu coolers and do a better job
  2. joluke
    joluke Notebook Deity
    Modified my Notepad U3 a bit more:
    Did bought a Dremel and cut the fans! Yes the work is not perfect but i kept it like this to keep the fans stable in the grid. Else i wouldn't have anywhere to screw them into!
    jc_denton, Papusan and Fire Tiger like this.
  3. joluke
    Update on my dremel cut for the air to flow more. Got a decrease of around 7 degrees (Celsius) in temperatures in my laptop due to it! Totally recommended!
    Fire Tiger and Papusan like this.
