missing battery indicator on task bar
Discussion in 'Lenovo' started by Swift, Nov 14, 2007.
  1. Swift
    Swift Notebook Enthusiast
    Anyone know how I can get it back? I have no idea what happened to it :|
  2. philfna
    philfna Notebook Evangelist NBR Reviewer
    I would reinstall the power management software from the Lenovo website. I suspect that will solve your problem quickly.
  3. JabbaJabba
    JabbaJabba ThinkPad Facilitator
    Try this:
    Go to ThinkVantage > Power Manager > Options.
    See if 'Show Power Manager Gauge in task bar' is unchecked for some reason. If it is, check it. Your battery gauge should now show on the taskbar.
    If this doesn't solve the issue, I would follow Phil's advice and reinstall Power Manager.
  4. Swift
    Thanks guys, I will try reinstalling it.
  5. ZaZ
    I find mine comes and goes from time to time. If you unlock the taskbar, it usually returns.
  6. JonathanA
    JonathanA Newbie
    Did the reinstallation work? I tried that on mine and there was no improvement, but I did find that by having a plain black desktop background the battery icon always appears! I assumed it is something to do with Vista aero, but have no real evidence. BTW I have an X61T with Vista Business
  7. JabbaJabba
    The issue you are referring to is a different issue. It seems, as you say, to be related to Vista's Aero feature and is a bug which Lenovo needs to fix.
  8. azngarrett
    azngarrett Newbie
    PLEASE READ THIS I FIGURED IT OUT!!
    i had this problem on my old laptop (IBM thinKpad, not sure what model) and have just had it happen again on my IBM THINKPAD R40. my neighbor showed me some stuff and i figured it out. go to START>RUN>type in MSCONFIG>STARTUP tab>check PWRMONIT. then restart. thats how it is on my PC. some computers may have something called "BATBAR" or "BAR.EXE" etc. look for a program in startup tab that has some words related to power or battery and make sure it's checked. if it already is, uncheck it, apply, restart, then recheck it and restart.
