Mini-PCI 4-port USB 2.0 Module
Discussion in 'Panasonic' started by ohlip, Oct 13, 2007.
  1. gravitar
    gravitar Notebook Deity
    thats a good point, i think the only way to pull that off is with right-angle connectors
  2. lameboyadvance
    lameboyadvance Newbie
    The Damozal model has right angle connectors, but as I said noone seems to sell it.
    Unless the AAEON model has the sockets soldered both sides, you should be able to use a soldering iron on them. If so, you could still use a heatgun or something to remove them.
  3. iNoob.x
    iNoob.x Notebook Evangelist
    Ok I just found this page using Google. I'm trying to do the same project, which is to add a few USB 2.0 ports to my pitiful 3xUSB 1.1 ports. I'm thinking about getting one of these mini-pci to usb modules and then connecting (the guts of) a usb hub to one of the usb ports on the module. The guts will then by put into my floppy drive (which is never used anymore) and will point out towards the opening of the floppy disk drive as extra usb ports. lol. seems like a long shot but I'm doing some research to see if it's feasible.
  4. gravitar
    Welcome! Are you doing this on a Toughbook (if so, what model) or on another brand?
  5. Toughbook
    He mentioned 3 USB 1.0 connectors... Did/Do Toughbooks have 3?
  6. gravitar
    i guess i need to read the whole message next time!
  7. mnementh
    mnementh Crusty Ol' TinkerDwagon
    I suspect he may be including the internal/unused ones we've found in the schematics...
    mnem
    up your USB!
