Mid-range laptop with decent graphics - shall I wait?
Discussion in 'What Notebook Should I Buy?' started by Balint Sipos, May 8, 2015.
  1. Balint Sipos
    Balint Sipos Notebook Enthusiast
    Hey guys,
    I am reasearching to buy a laptop for my fiance to replace her old(er) Packard-Bell piece. Can you please help with finding the right one?
    Now here are the criterias:
    - larger than 13" but not 17" Full HD screen
    - decent battery time 4+ hours (under normal use - films, internet)
    - fairly ligthweight (doesn't need to be superlight just not like my 4.5kg rig)
    - ok(ish) graphic output. either a higher end integrated card (iris pro maybe?) or dedicated graphics (keep in mind that with dedicated the battery time is much worse and I try to avoid that). It should run things like: Dota 2, Orcs must Die2, Divinity Original Sin
    - hybrid hard drive or just SSD
    - AC wifi
    - cost: max 1000-1100 $ (can be way less of course if there are options)
    Now the one I have found so far is a custom made one from XoticPC: http://www.xoticpc.com/sager-np2740-clevo-w740su-p-6201.html
    SAGER NP2740 (Clevo w740SU)
    14.1" FHD
    i7-4770HQ
    Intel® Iris Pro 5200 Graphics
    8GB DDR3 1600MHz
    4.20 lbs with 6-cell Battery
    Can you comment on this and maybe recommend better ones that suit these criterias?
    Since the new Broadwells and a bit later the Skylakes are coming out, shall I wait a bit so the prices for 4th gen CPUs get lower or even wait for these new ones? Would it worth it?
    Any help is appreciated :)
    Thanks a lot
    Balint
  2. derkeysersoze
    derkeysersoze Notebook Consultant
  3. TomJGX
    TomJGX I HATE BGA!
    If you can push to 1100-1300, you can get the Sager NP8651 with 970M.. it will be perfect and quite futureproof.. otherwise, the Y50 is available for less but with 860M.. There are a few sales so price is around 800-900 for 1080p IPS model.. Do not get the other screen models as they're crap..
  4. Balint Sipos
    Thanks guys. I've checked the Y50 and for this price point it has pretty good specs. Although it's getting a lot of bad reviews apparently. Not sure if I believe those though.
    I wouldn't go as far as the Sager NP8651 as the video card is unecessary. The laptop isn't supposed to be a heavy gaming laptop, weight and battery life are bigger concerns to my girlfriend. I always glance back at the Sager NP2740 because of this. A decent integrated video card would make the laptop less heavy and improve the battery quite a lot. But I can be convinced otherwise :)
  5. derkeysersoze
    a lot of the bad reviews are from the older non-IPS screen. the special going on now is 899 and has the IPS screen. i personally owned a touch version of the Y50 and liked it except the screen wasn't the best.
    edit; let me clarify. I owned the y50 prior to the IPS update. i had no complaints about the machine except the screen and that seems to be addressed and no longer a problem.
  6. Balint Sipos
    cool that sounds much better. how was your battery life during non-gaming circumstances?
  7. derkeysersoze
    When i used it at the coffee shop i would play some games and browse. i would say around 4 hours with wifi + low power mode ( it restricted the CPU to around 1.6 ghz ) and maybe 2 hours when playing a game.
