Microphone Sensitivity
Discussion in 'Alienware M11x' started by shortyyguy, Sep 24, 2011.
  1. shortyyguy
    shortyyguy Newbie
    Is there any way to turn down the sensitivity on the built-in microphone in the M11x-R2?
    It literally picks up every little sound in the house when it's on. It'll even sense a pin dropping ... I've tested it. I just want to Skype some one without them hearing every bit of my life in the background.
  2. un4tural
    un4tural Notebook Evangelist
    Skype auto adjusts sensitivity to a proper level... if you got to settings -> options and sound and something one or another you can see that. if you're still unhappy you can right click the little speaker to the left of the clock and select recording devices where you can adjust pretty much anything adjustable by selecting the mic and clicking PROPERTIES.
    I think that covers that
  3. shortyyguy
    shortyyguy Newbie
    ya ive done all that but there's nothing that says microphone sensitivity, just volume and boost
  4. un4tural
    ... not looking hard enough little grass hopper
    Right click speaker -> click Recording devices -> Recording tab -> Click microphone -> Click Properties -> Levels tab -> you can disable the Boost and lower the volume of the microphone.
    and seriously is it that hard to go to google type into the little search box "adjust microphone sensitivity windows 7"... Here ill even 1UP you adjust microphone sensitivity windows 7 - Google Search
    Now stop trolling and do something else
  5. MasivB
    MasivB Guest
    Well I mean, he is posting on the forums to get support. If your best advice of support is "search it on google" you're the one that needs to stop trolling. As for the problem. Try enabling noise suppression if you haven't already.
Similar Threads - Microphone Sensitivity
  1. locksmth
    420
  2. etcetera
    283
