microphone always active! why ?
Discussion in 'Windows OS and Software' started by tinto101, Jul 21, 2008.
  1. tinto101
    tinto101 Notebook Enthusiast
    big problem... i see that in this week the 2 microphone
    on the top of my pc portable notebook is alway
    active ! infact if i talk near i hear my voice in the
    notebook speakers !!!! why ?
    i not try the system to turn off the microphone !
    and i see that the simply windows xp program
    to record NOT record my voice !!!!
    in how mode i turn off the microphone always
    ON !
    i see only the command to regulated with
    the cursors the volume ....
    help me
  2. sweetStyles
    sweetStyles Notebook Consultant
    Try going to control panel > sound > playback or something similar and look for your mics. Just one of them, and see if it goes away. If not, disable the other and just use one.
  3. Nocturnal310
    Nocturnal310 Notebook Virtuoso
    Wow, and i WANT that to happen and it aint happening..its called line-in monitoring.
  4. Buddybot111
    Buddybot111 Notebook Consultant
    Problem is your mic is setup as a "line-in" instead of microphone. Make sure you have it plugged into the correct port and that in your soundcard settings "microphone" is enabled instead of "line-in" for that port.
  5. flipfire
    flipfire Moderately Boss
    Double click the sound icon on the task bar and tick the Mute box for Microphone
  6. knightingmagic
    knightingmagic Notebook Deity
    Yeah that's it.
