Microlags Fix
Discussion in 'Windows OS and Software' started by Danishblunt, Jan 21, 2018.
  1. Danishblunt
    Danishblunt Notebook Virtuoso
    Not yet, awaiting NVIDIAS response.
    Vasudev likes this.
  2. Danishblunt
    So after doing some more digging, this seems to be NVIDIA again, talked to a couple of AMD enduro owners, they don't have the issue, meaning intel + windows are not at fault here.
    Vasudev likes this.
  3. Vasudev
    Vasudev Notebook Prophet
    Intel+AMD doesn't have any issues.
  4. Danishblunt
    The irony is quite impressive.
  5. Vasudev
    I mean switchable gfx works correctly.
    Well, as a matter of fact I found a way to use Shum rendering options for Optimus flag to MS_HYBRID which forces iGPU to be enabled and turns off nvidia. You can use nvidia inspector to achieve that. dGPU won't wake unless you change it back.
  6. Danishblunt
    That's not a solution, since I could achieve the same by simply disabling the nvidia GPU in device manager.
  7. Vasudev
    This takes off dGPU completely, until you change to Optimus default value.
  8. Danishblunt
    can't find MS hybrid btw.
    EDIT: didn't change a thing, still lagged and changed to dGPU
    Vasudev likes this.
  9. Vasudev
    Did you install phoenix's recommended intel driver?
  10. Danishblunt
    Everything up 2 date and recommended drivers, yes. NVIDIA needs to fix this somehow.
    Vasudev likes this.
