Micro SD flush with side in M11 R2
Discussion in 'Alienware M11x' started by mcrustk2, Jul 12, 2011.
  1. ejohnson
    ejohnson Is that lemon zest?
    Where did you order from? Alot of places no longer contact you after purchise. They just take your money and ship the items.
  2. Zuluuk
    Zuluuk Notebook Enthusiast
    Not sure if you can make a raid out of these because the OS sees them as external removable media.
  3. thegh0sts
    thegh0sts Notebook Nobel Laureate
    i got mine from ebay, the link ejohnson provided.
    funnily enough i got a message from the seller saying the adapter was shipped.
    would the adapter appear even though there's no card in it?
  4. ejohnson
    hmm... thats a good question. It might show up as a USB device with no card in it, but chances are you will have to insert a card before something comes up.
  5. thegh0sts
    true, i have a USB card reader on my monitor and i just plugged it in and nothing shows up in my computer but device manager definitely says it's there but as unused drive letters.
    EDIT: here's a comparison PDF.
    http://www.hwtools.net/PDF/SD cardreader comparison.pdf
    i think the one on the very left is the one I bought off ebay as the listing says it's USB 2.0.
  6. ejohnson
    Looking at that PDF, look at MR09R... its a micro sd card reader, but it has 2 antenna plugs on it also.
    http://www.hwtools.net/cardreader/MR09R.html
  7. thegh0sts
    i wonder what the theoretical speed would be and which is it most dependent on? the card or the adapter?
    EDIT: just wondering as I would like to dump some games to a 32gb SDHC card and see how it fairs.
  8. emike09
    emike09 Overclocking Champion
  9. thegh0sts
    the connector uses USB controllers so the SSD would need the controller on the drive.
  10. potentiality
    potentiality Notebook Consultant
    Even if they can get the bios to see the other slot as not for the wwan. Getting a ssd for it would be like taking a Ferrari, and putting it into LA Traffic. That PCI E is still using USB 2.0 which cant get past 60MBs. When most of the time thats about half because of CPU use.
    The smartcards are the right idea, and I hope to hear results soon as I had the same idea before with cutting an external to be flush to keep windows temp swap, page, and downloaded files on.
    http://forum.notebookreview.com/alienware-m11x/575083-m11x-r2-card-read-can-read-sdhc.html
