Micro 10 Pro 20H2 19042.630
Discussion in 'Windows OS and Software' started by MaheshKondraju, Nov 14, 2020.
  1. MaheshKondraju
    MaheshKondraju Notebook Guru
    Full: This version is for folks who are interested in Complete Windows 10 Features where Windows can be updated and Windows 10 Universal Apps can be installed from Windows Store along with few tweaks.
    Slim: This version is for folks who are interested in Complete Windows 10 Desktop Environment Features where windows can not be updated, no Windows Store & no Windows 10 Universal Apps.
    Extreme: This version is for folks who are interested in stable yet heavily stripped down Windows 10 Desktop Environment which includes stock Dot Net Framework 2.0, 3.0, 3.5 & 4.0 for stability of the OS.
    Barebone: This version is for folks who are enthusiasts & interested in Experimental Windows 10 Desktop Environment which includes stripped down Dot Net Framework 2.0, 3.0, 3.5 & 4.0.
    Barebone Dot Net Framework 4.0 Only: This version is for folks who doesn't use software based on Dot Net Framework 2.0, 3.0 & 3.5.
    Micro 10 Pro 20H2 19042.630 Slim:
    Release Notes:
    ISO file size weighs at 1.91 GB and installation consumes 6.27 GB
    Feature List:
    All Windows 10 Desktop Environment Features are intact.
    All Drivers are intact.
    Removed Universal Windows Apps & Windows Store Support.
    Removed Winsxs, So Windows Update doesn't work.
    Includes a new stripped down boot wim with better Storage Controller Drivers support for various Hardware.
    New AutoUnattended.xml where end user can name his Windows Installation.
    Restored Old Classic Search Box in Windows 10 File Explorer with a registry hack, So that we can have instant search results display as soon as we start typing.
    EFI Support is intact.
    Compressed to ESD.
    Registry and Services not heavily tweaked, as all Windows 10 Desktop Environment Features are intact.
    Removed Features:
    Miscellaneous Temp Files, Windows Recovery Backup File, Winsxs, Windows 10 Universal Apps and Windows Store support.
    Known Issues:
    None
    Note:
    Use HJSplit to join the files
    Download Link:
    https://mega.nz/folder/NtEijRjb#F8kc0isY1l4KlFeB3DF9yg
    Micro 10 Pro 20H2 19042.630 Extreme:
    Release Notes:
    ISO file size weighs at 886 MB and installation consumes 3.40 GB
    Feature List:
    Just a Core OS.
    Includes Stock Dot Net Framework 2.0, 3.0, 3.5 & 4.0 for stability of the OS.
    Winsxs is removed So windows Update doesn't work.
    Administrative Tools like Event Viewer, Task Scheduler etc has been removed
    Internet Explorer has been removed
    Cortana, Onedrive, Windows Defender, Telemetry & Action Center has been removed.
    Drivers has been removed but with better Storage Controller Drivers support for various Hardware.
    Printers, Scanners works.
    Only System Core Fonts present.
    Compressed to ESD
    Registry and Services has been Tweaked heavily.
    Removed Features:
    Temp Files, Windows Recovery Backup file,Winsxs, Windows 10 Universal Apps & Windows Store support, Windows Defender, Dictionaries, Spelling, Speech support & its App Narrator, IME languages, Input Methods, Help & Stock Dot Net Framework.
    Known Issues:
    None
    Note:
    Download Link:
    https://mega.nz/folder/B8EgwLab#aswTehnwk78bbLUWSGWZ2A
    Micro 10 Pro 20H2 19042.630 Barebone:
    Release Notes:
    ISO file size weighs at 825 MB and installation consumes 2.90 GB
    Feature List:
    Just a Core OS.
    Includes new Experimental stripped down Dot Net Framework 2.0, 3.0, 3.5 & 4.0 ( Some Software might not work)
    Compressed to ESD
    Removed Features:
    Known Issues:
    None
    Note:
    Download Link:
    https://mega.nz/folder/9tE2VZRC#tHYyuckICIGU0xysW9N6Uw
    Micro 10 Pro 20H2 19042.630 Barebone Dot Net Framework 4.0 Only:
    Release Notes:
    ISO file size weighs at 792 MB and installation consumes 2.66 GB
    Feature List:
    Just a Core OS.
    Includes new Experimental stripped down Dot Net Framework 4.0 Only ( Some Software might not work)
    Compressed to ESD
    Removed Features:
    Known Issues:
    None
    Note:
    Download Link:
    https://mega.nz/folder/RgVwkRhI#vR-_JmbyBXuNDYK5_lrFgQ
    Micro 10 Pro 20H2 19042.630 Barebone Dot Net Framework 4.0 DLL's Removed:
    Release Notes:
    ISO file size weighs at 682 MB and installation consumes 2.25 GB
    Feature List:
    Lots of System Dll's has been removed (not sure whether stable or not), Test with the set of Software you use with your daily driver & Let me know.
    Just a Core OS.
    Compressed to ESD
    Removed Features:
    Known Issues:
    None
    Note:
    Download Link:
    https://mega.nz/folder/QoVgETxQ#OZQteOFz2UeKuzEbCBM5-A
    zerocoolroot likes this.
  2. Wildroar
    Wildroar Newbie
    sorry for my noob question. I can't install extreme version, always has the error missing driver then my pc can't load disk drive. Pls give me some guide
  3. MaheshKondraju
    May i know your chipset & Storage Controller ?
    I have retained most of the stock storage controller drivers from microsoft.
  4. zerocoolroot
    zerocoolroot Newbie
    Hi @MaheshKondraju,
    Did you use WinReducer..?? If yes, woul'd you can to share your Slim and Extreme Preset..??
    Thanks in advance..!!
  5. StormJumper
    StormJumper Notebook Virtuoso
    I recommend anyone not familiar doing this not advised to do this. You should have a recovery disk or MS OEM W10 dvd or USB to install. This is the proper way to insure you have all the drivers/software to operate your hardware correctly. This should only be for Testing Purpse Only. So use your OEM recovery install or OEM USB/DVD driver to reinstall factory OEM otherwise if self installed you should have a full installer USB/DVD to properly install.
    0lok likes this.
  6. Wildroar
    Wildroar Newbie
    It's intel HM175. One thing need to know, which version can using office 365 with syncing document work well?
    Sent from my SM-G9650 using Tapatalk
  7. StormJumper
    You wat to look here to do or find what your doing. This site doesn't provide actual 365 support questions but only user experience help.
    https://support.microsoft.com/en-us/office/sync-sharepoint-and-teams-files-with-your-computer-6de9ede8-5b6e-4503-80b2-6190f3354a88#:~:text=Change sync settings-,Set up syncing,Select Sync.
  8. MaheshKondraju
    are you able to install the os sucessfully ? if not integrate your intel HM175 chipset drivers to the boot wim & install wim file using ntlite, it should install on to your hard drive.
    Well with regards to office 365 i have no idea mate, as for what you are looking.
  9. Wildroar
    Wildroar Newbie
    Tks! Not sucessful, stuck at missing driver. But your iso havent got install wim file, just instal.esd. Do i need to convert esd to wim file?
  10. MaheshKondraju
    yes convert esd to wim using ntlite
    Wildroar likes this.
