Micro 10 Pro 20H1 2004.450
Discussion in 'Windows OS and Software' started by MaheshKondraju, Aug 11, 2020.
  1. MaheshKondraju
    MaheshKondraju Notebook Guru
    Full: This version is for Folks who are interested in Full Windows 10 where Windows can be updated and Apps can be installed from Windows Store along with few tweaks here and there.
    Slim: This version is for Folks who are interested in Full Windows 10 Desktop Environment where windows can not be updated, no Windows Store & no Windows 10 Universal Apps.
    Extreme: This version is for Folks who are interested in Stable yet heavily stripped down Desktop Environment.
    Barebone: This version is for Folks who are enthusiasts & interested in Experimental Desktop Environment.
    Micro 10 Pro 20H1 2004.450 64 Bit Extreme:
    Release Notes:
    ISO file size weighs at 898 MB and installation consumes 3.52 GB
    Feature List:
    Includes Stock Dot Net 2.0, 3.0, 3.5 & 4.0 for stability of the OS.
    Winsxs is removed So windows Update doesn't works but drivers can be installed.
    Just a Core OS.
    Administrative Tools like Event Viewer, Task Scheduler etc has been removed
    Internet Explorer Still works
    Printer Support is intact, need to check whether Printers, Scanners & Fax Machines works or not.
    Drivers has been removed.
    Only System Core Fonts present.
    Cortana, Onedrive, Windows Defender, Telemetry & Action Center has been removed.
    EFI Support has been removed
    Compressed to ESD
    Registry and Services have been Tweaked heavily.
    Includes a new stripped down boot wim to reduce overall iso footprint
    Removed Features:
    Temp Files, Windows Recovery Backup file,Winsxs, Windows 10 Universal Apps & Windows Store support, Windows Defender, Dictionaries, Spelling, Speech support & its App Narrator, IME languages, Input Methods, Help & Stock Dot Net Framework.
    Known Issues:
    None
    Note:
    Use HJSplit to join the files
    Download Link:
    https://mega.nz/folder/J88wBa7L#5_Us6DO1DyMXIlFOUhfCxA
    Micro 10 Pro 20H1 2004.450 64 Bit Barebone:
    Release Notes:
    ISO file size weighs at 839 MB and installation consumes 2.96 GB
    Feature List:
    Includes new Experimental stripped down Dot Net Framework 2.0, 3.0, 3.5 & 4.0 ( Some Software might not work)
    Just a Core OS.
    Compressed to ESD
    Removed Features:
    Known Issues:
    None
    Note:
    Download Link:
    https://mega.nz/folder/0p9WhIaT#F800F6zEa5wzb_vKG97-ew
    Micro 10 Pro 20H1 2004.450 64 Bit Barebone Dot Net Framework 4 Only:
    Release Notes:
    ISO file size weighs at 807 MB and installation consumes 2.76 GB
    Feature List:
    Includes new Experimental stripped down Dot Net Framework 4.0 only ( Some Software might not work)
    Just a Core OS.
    Compressed to ESD
    Removed Features:
    Known Issues:
    None
    Note:
    Download Link:
    https://mega.nz/folder/stlCAaAQ#qnyT-0i_lP0vFC5Ev3lCHA
    Micro 10 Pro 20H1 2004.450 64 Bit Barebone Dot Net Framework 4 Only DLL's Removed:
    Release Notes:
    ISO file size weighs at 647 MB and installation consumes 2.19 GB
    Feature List:
    Lots of system dll's has been removed (not sure whether stable or not).
    Windows Update completely removed, cant even update drivers.
    Battery Power Mode Slider has been fixed.
    Video Thumbnails has been fixed
    Just a Core OS.
    Compressed to ESD
    Removed Features:
    Known Issues:
    None
    Note:
    Download Link:
    https://mega.nz/folder/45tWzSYR#-sEXAInNQDqQzpDDTLHCpQ
  2. MaheshKondraju
    Micro 10 Pro 20H1 2004.450 Barebone version with August 2020 update has been released.
    Here is a registry file to enable hidden features of 20H1 build, which enables new start menu look of 20H2 build.
    http://www.mediafire.com/folder/72mgg4ilu74rt/20H2_Features
    Micro 10 Pro 20H1 2004 Start Menu Look & Feel
    Micro 10 Pro 20H2 2009 Start Menu Look & Feel
    steberg likes this.
  3. MaheshKondraju
    released altogether 4 versions based on Windows 10 Pro 20H1 2004.450, choose versions based on your usage.
    cheers
  4. MaheshKondraju
    no full & slim this time in 20H1 release
  5. call4mac
    call4mac Newbie
    Unable to get any slim-down windows 2004 to work on my ryzen 5. original windows 10 2004 work will ok. Blue screen of death when iso is run. Not just your iso but all.
  6. MaheshKondraju
    just integrate your chipset drivers like amdsata etc and nvme drivers if you use, into boot wim as well as install wim.
  7. call4mac
    call4mac Newbie
  8. MaheshKondraju
    Papusan likes this.
  9. call4mac
    call4mac Newbie
    Your work on slimming down windows is awesome. I really appreciate what you have done. Your presets are great, keep up the good work.
